Results 1 to 6 of 6
    Redfox0099's Avatar
    North Charleston, SC
    Help needed with Strange Headlight not working issue
    My left headlight is out so I thought it was just my HID bulb is bad....put the bulb in from the other side that works and it doesn't work either.
    Checked all the fuses I can see up front and none are blown.
    Used a test light and there is power all the way to the plug in for the low beam headlight.
    Put a stock headlight bulb back in and it doesn't turn on but again there is power to that connector according to my test light....
    Thoughts?
    Redfox0099's Avatar
    actually it looks like only my right side low beam is working and it is an HID, I have the car turned off but flipped the high beams on and nothing came on.
    Jaak's Avatar
    May 2005
    What's the voltage across the stock headlight bulb when it didn't light?
    If it's 12 volts, then the bulb isn't drawing current. If it's very low, then you've got something elsewhere (driver in the FCM?) that has cooked and can't provide enough current.
    Just thoughts, without being there, I can't really troubleshoot it well.
    2006 Magnum SRT8 - 11.85@117
    Chronic01505's Avatar
    Chronic01505 is offline I'M THROWED
    Sep 2007
    Maple Grove MN
    I would recommend triple checking the fuses... an then check the fuses 1 more time.
    Sounds like a dreaded electrical problem. Take it to the dealer just get a quote. They will tell you whats wrong in the end then just fix it yourself.
    2005 Dodge Magnum RT (RED)
    Features: Auto Lights, Chrome Vent Fins, Platinum Spark Plugs, MyGIG. Uconnect (08 LX Mirror) Alpine Solo X, Alpine 2000W Amp, Alpine 1000:1 Amp, 2 Rockford 500k- 1 faret total Cap
    Future Mods: 2Way Remote Start, Removal of the Roof Rack, (for sale if anyone wants it pm me) Superchip (not sure what one)
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Nathan are all the grounds tight?
    BFNY PERFORMANCE
    RIP My Friend
    Redfox0099's Avatar
    I will check again on the grounds and the fuses after SEMA...lucky for me I don't have to drive it at night for a while
    Thanks for the help guys, we did move my HID Ballasts when we installed the ProCharger but John didn't unplug anything just moved it and it has power...just need to check the grounds I guess.
