Results 1 to 15 of 15
    1sthemi's Avatar
    1sthemi is offline LX Newbie
    May 2006
    HELP!!! I need a relay specialist!!
    I need to know if any one on here are familiar with relays and how they work. I want to wire some up to have a latched on or off status with just the touch of 2 wires only! I have a setup of four relays wired to eachother which i have the on and off option but its with 3 wires though. If i touch the ground on one wire it wud make the relay atch on and if i touch the ground with the other wire it latches off. Is the a way i can use the ground witth just one wire to have a on and off function
    plcman's Avatar
    plcman is offline Plcman Charger R/T
    Nov 2005
    Jacksonville,Fl.
    Yep I will draw it up for you.
    R.I.P LOU1355
    2006 Charger R/T R&T - Ordered 9-06-05- Home 12-23-05 - Mods: SRT Hood, 180 Degree Thermostat, JBA Shorties, High FLow Cats, SRT Suspension, AFE Stage II CAI, ---Painted Half covers --- AMG Paddles--Jaak Hack direct wire--PLCMAN Line-Lock board SLP Line Lock ---raymond@plcmanguy.com
    FLXC.ORG ---North Chapter Coordinator---Hemi Registry # 00648 plcman Thanks Billet Technology 2008 Shindig winner under the hood goodies!
    plcman's Avatar
    Nov 2005
    Jacksonville,Fl.
    Here ya go!!
    R.I.P LOU1355
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    Do you see what I'm saying about this guy!?
    Hemi Wagon's Avatar
    Hemi Wagon is offline Officer are you sure???
    Jul 2008
    MD
    Quote Originally Posted by plcman View Post
    Here ya go!!
    Now can we see it in laymans terms..............LOL
    Silver Bullet
    5.7 Hemi Registry #949
    Baltimore Mopar Motor Club #008
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    Cool cad drawing Ray... but im LOST... LOL
    -Ryan
    <<<clicky...
    '93 1500 SB - 226k, '05 Magnum RT - 17k, '80 El Camino - 84k
    radioactive's Avatar
    radioactive is offline LX Padiwan
    Sep 2007
    Tullahoma, TN
    Why not just buy a latching relay?
    1sthemi's Avatar
    May 2006
    Is that setup for regular relays that have 87,87a,86,85 and 30 on them or is that a different relay setup? Below is what i thought mite had worked but i can only get it to work with 3 wires instant of 2
    plcman's Avatar
    Nov 2005
    Jacksonville,Fl.
    Quote Originally Posted by 1sthemi View Post
    This circuit will work, with one button, I have transposed it to ladder I will make a cad of the equivalent drawing later.
    This is how the above circuit works:
    First we have to assign relay numbers to the above drawing.
    Working from the left this will be R1 then R2 and so on.
    Press the button and R1 energizes through the NC of R3, turning the 12v output on. The connection to the output is connected to the coil of R2 which latches R2 through the NO of R2 and the NC of R4. Now R1 is on, and because the output is latched with R2 it in-turn turns on R3 through the NC of R1 when the button is released and R1 is reset.
    The unlatch is a little more complicated.
    To unlatch the follow happens:
    Now remember R3 is on with R2. So when the button is pushed again, the current now flows to the coil of R4 through the NO of R3 which is on. The diode blocks the current flow back to the output and keeps R1 from keeping R3 latched. This unlatches R2 and resets R2 to it's normal off state, because R4 NC is now open and the NO of R4 is closed this now holds R3 on and holds R4 on until the button is released, which then releases R3 and R4 and the circuit is reset.
    I will post the Ladder equivalent later.
    Raymond
    R.I.P LOU1355
    1sthemi's Avatar
    May 2006
    Thanx your smart! I got it 2 work
    KStryker's Avatar
    KStryker is offline Strike First, Strike Hard!!
    Mar 2008
    GALXC
    OMG is this stuff in english!!!
    TorRed 2007 Charger R/T, Hemi Registry #1060
    Appearance: Painted SRT8 Fascia/Rims/Spoiler; Daytona Grill; CBD CF SRT8 Hood; Painted Calipers; R/T Badge on Fenders; Ridergraphix Decals; OEM HIDS; Billet Tech Goodies.
    Performance: aFe Stage II CAI, Diablo Predator Perf CAI 93, SRT Suspension, Corsa Xtreme.
    plcman's Avatar
    Nov 2005
    Jacksonville,Fl.
    I am glad you got it worked out, also I posted the logic in ladder form for all to follow.
    R.I.P LOU1355
    plcman's Avatar
    Nov 2005
    Jacksonville,Fl.
    This diagram is easier to wire, all the relays have a common tie point for the coils, no grounding to activate. This causes a false trigger to happen, if you have a short to ground in the button circuit.
    This is the same circuit as was posted but with some changes.
    If anyone wants this in PDF format I can email it to you, I cannot PM it to you.
    Raymond
    R.I.P LOU1355
    05Silver_C's Avatar
    05Silver_C is offline Army Bomb Tech
    Fort Lee, VA
    Umm... I cant remember how exactly to do it, and I dont have my electronics kit over here in Iraq with me, but Im pretty sure there is a much more efficient and simple way to make this switch by using an SCR
    2005 Bright Silver Metallic 300C (Stolen, Recovered, Sold to another member)
    2007 Yellow Super Bee Charger SRT8 #0960 of 1000
    2009 Modern Blue Pearl Grand Cherokee SRT8
    "Viewed from half a world away, a bomb is a political concern; viewed from less than a foot away, a bomb is just a high-stakes exercise in problem-solving, where making a mistake means a final, terminal education in the physics of expanding gases"
    plcman's Avatar
    Nov 2005
    Jacksonville,Fl.
    I have many ways to do this, he wanted to use only relays.
    R.I.P LOU1355
