Results 1 to 8 of 8
    bskylerj's Avatar
    bskylerj is online now SICK 392
    Nov 2006
    Spokane, WA
    Has anyone had this issue with your factory nav?
    I just installed a factory nav unit. I also installed a iPod control box so the iPod can be run though the stereo. When I leave the sat radio area and then come back my preset sat channels are gone. The memory retains everything else, just not the sat stations? Any ideas? Is there a reset button on this unit?
    Thanks
    2011 SRT8 392 Challenger. Black, Loaded, Stripe delete. 22x9 front and 22x10.5 rear
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    no reset button...
    sounds like a loose connection somewhere.....
    the unit itself should always retain the station memory even if unplugged...
    now the issue with the SAT/ Ipod I can't really address because I don't have SAT..
    hopefully Jaak will chime in.
    but seeing as the Mopar Ipod interface works on the SAT link, my thinking would be that if you attempted to set or change the preset memory in ipod mode then it would wipe out the SAT memory since the ipod interface is emulating the SAT mode features..
    bskylerj's Avatar
    Nov 2006
    Spokane, WA
    so would I need to disconnect the iPod adapter then save them, then rehook up the iPod adapted
    Apr 2006
    Quote Originally Posted by bskylerj View Post
    that would be where I would start
    Toronto, Ontario
    Sounds like it's working properly.
    I have the same setup you do, minus the SAT radio. While looking into the iPod module, I did find that the module tells the stereo that it is the SAT system. All the channel info is dumped and replaced with the info off the iPod. So when you go back to the actual SAT radio, it has to update everything all over again.
    I'll dig up the thread I saw the info in for you.
    Edit;
    More info in here: Ipod connector pictures!!! here first!!!
    2007 Dodge Magnum R/T AWD - Bright Silver - NAV - iPod - VES - True SRT Grille from dodgemagnumgrilles - Predator 91 Tune - BT Catch Can - R1 Concepts Premium Rotors & PosiQuiet Pads
    bskylerj's Avatar
    Nov 2006
    Spokane, WA
    thanks for the help
    magnumfloyd's Avatar
    magnumfloyd is offline LX Newbie
    Nov 2005
    New Jersey
    what i pod control box are you using I have the mopar piece and have no problems
    MoparPosterChild's Avatar
    MoparPosterChild is offline MOPAR Poster Child
    Dec 2006
    When you have the ipod adaptor, you lose the ability to store channels. Every time you start the car it will clear the channels from the memory. It's a trade off of having the ipod adaptor.
    2010 Dodge Challenger SRT-8 Magnaflow exhaust Kicker dual 10" sub enclosure Billet Tech engine bay goodies HOTCHKIS Stage-1 TVS Magnuson supercharger FOOSE speed wheels BFG KDW tires
    1970 Plymouth Duster 406" Stroker from MOPAR Performance
    1969 Charger 500" Stroker motor 585hp 618 ft/lbs
    1972 Charger Mopar 392 HEMI, Viper 6-speed, FOOSE Challenger wheels, and much much more!
    MOPAR or NO CAR
