Results 1 to 11 of 11
    Earcandy's Avatar
    Earcandy is offline MAG DADDY
    Burlingon, North Carolina
    Harness for upgrading sound system
    There is a Metra harness for the magnum part# 70-6504 it has a plug for the radio and two more for the factory amp and ample wire to go fro the amp to the radio opening. even comes with a wire and tap for the acc. connection. works really well.
    Just thought you might like to know. :D
    Thanks for the Avatar, Hazman
    Mine:
    Hers: :downboy:
    Mine::twisted:
    51 Chevy pick-up
    http://www.soundsweet.com
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    Thanks for the info.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    ldavenci is offline LX Newbie
    PA
    Re: Harness for upgrading sound system
    Quote Originally Posted by Earcandy
    There is a Metra harness for the magnum part# 70-6507 it has a plug for the radio and two more for the factory amp and ample wire to go fro the amp to the radio opening. even comes with a wire and tap for the acc. connection. works really well.
    Does this work with the factory Nav?
    500 hp V8 daily driver...or bust!!!!
    Earcandy's Avatar
    More than likely the harness will work but the factory nav system will probably have a few more plugs attached to it that will not be used in a stereo upgrade which is what this harness is for, unless you are trying to add an aftermarket amp to a fac nav system in that case this harness would come in handy. :D
    Mine:
    Hers: :downboy:
    Mine::twisted:
    51 Chevy pick-up
    Earcandy's Avatar
    sorry fellas I was off on the part# the real #is 70-6504 I have denied myself any cigar smoking for the next 15 minutes for this.
    Mine:
    Hers: :downboy:
    Mine::twisted:
    51 Chevy pick-up
    IDSmoker's Avatar
    IDSmoker is offline LX Padiwan
    Boise, ID
    I thought this thread might be an appropiate place for this information as well.
    If you want to use an Aux audio input with one of the factory radios, it looks like your only choice at the moment is to use an FM modulator. You can get one of these just about anywhere (try google), but you will probably also need these antenna adapter cables:
    I don't know whether you'll need both or just one of them, but once I finally get my Magnum, I'll be doing this mod in ORDER to use my iPod, and I will try to do a How-To if no one else has by then.
    snickle's Avatar
    snickle is offline LX Old Timer
    May 2004
    I am planning a FM Modulator very soon. Just need to find the time.
    2005 Dodge Magnum RT - Midnight Blue Pearl
    Volant CAI, 190 Thermo, Mr. Grille Vertical Grille,
    SXT Headlights, MDS Monitor, Bel 975R,
    Infinity 3002cf (dash),Blaupunkt 605 woofer (door), Infinity 6002si (Rear),Infinity Basslink, SC Tuner, GSM Fan/Traction Mod, 22elite Heal Guard, Factory One Tail lights
    UnderTaker's Avatar
    UnderTaker is offline Bring out your dead!
    Oct 2004
    Norwalk, Connecticut.
    i am HAVING a hard time finding this part you speak of.. can someone post a hyperlink that would be very helpful. thanks
    05 Blk Magnum RT RWD,Window Tint, Mopar CAI, B&G PCM Flash, Magnaflow Cats, Borla 125, "HEARSE" vanity plate, AR/311 20" wheels W/Goodyear F1 245/45/20, 4X R1 D&S Rotors, LED tails, AAC Halo's suck - replaced with 402 motoring lights (sweet), Custom LED turns, Wired V1 W/Remote Disp, Kenwood Excelon 715dvd w/ NAV, iPod, 2x Diamond Hex 6.5, Eclipse Titanium DVC 12" w/custom enclosure, JL 1000/1, 2x JL 300/2, 2X Optima Batt. w/ Isolator, Rear Shaved, R Sylvania Turns
    Earcandy's Avatar
    Quote Originally Posted by UnderTaker
    You should be able to get it FROM any GOOD car audio shop or you can message me and I will get it to you.
    Mine:
    Hers: :downboy:
    Mine::twisted:
    51 Chevy pick-up
    henry's Avatar
    henry is offline Cunning Stunt
    Jul 2004
    43 39' N; 79 23' W
    Does this harness have a line level converter on it?
    I'm assuming that it is just a harness and we're on our own for line level conversion or the use of amplifiers with high level inputs. Any info?
    Thanks
    Henry
    Earcandy's Avatar
    Quote Originally Posted by henry
    Thanks
    Henry
    The harness will allow you to install equipment without cutting the factory wiring.
    it does not include a level converter. CHECK here for a good high quality converterwww.davidnavone.com
    Mine:
    Hers: :downboy:
    Mine::twisted:
    51 Chevy pick-up
