Results 1 to 15 of 27
    smokey0810's Avatar
    smokey0810 is offline LX Padiwan
    Gonna Do It Myself...
    Figure to keep the cost down, I'll install the sub MYSELF. Can anyone give me a makeshift diagram of adding the subwoofer to the speakers....I know how to hook up the amp & all, just wanted to get an idea of splicing the speaker wires from the amp into the stock speakers....Do I run both wires to one speaker, or what?
    Thanks in advance, John
    '06 Jeep Grand Cherokee Laredo
    No Mods Yet...Some On There Way....
    smokey0810's Avatar
    One more thing...I guess I need a 2-channel amp to run this setup, correct?
    Magnum-RT-AWD is offline 12-Volt-Guru
    Dec 2004
    Christiansburg Va
    If you are just adding a subwoofer---a Monoblock Class D amp will do the trick.
    2005 Dodge Magnum RT AWD "Cool Vanilla"
    Pioneer Premier DEX P9
    Pioneer Premier DEQ P9
    Vifa M18WN19-04 midbass
    Vifa DX25tg-05-04 tweets
    Phoenix Gold MS1000TA
    Adire Audio Brahma MKII 15
    2.75 cubes sealed enclosure
    Adire/Ampman Revolution 1500.1D----retired for now
    SunDown Audio(prototype 1500 sub amp---quite the powerhouse)
    3500 watts of SQ!!
    http://www.sounddomain.com/ride/2112117
    smokey0810's Avatar
    Crutchfield has a pretty decent deal on a Rockford 12" Sub & 2-channel amp...Just need a box and power hookup.
    Now, there is NO NEED to touch the headunit, right? Just "splice" the speaker wires into the front speakers???
    Dec 2004
    Christiansburg Va
    HU is ok left alone----just get a line-level adapter and whatever sub/amp combo you want(afford)
    3500 watts of SQ!!
    smokey0810's Avatar
    Line level adapter as in a Line Output Convertor?
    Dec 2004
    Christiansburg Va
    yes!!
    3500 watts of SQ!!
    smokey0810's Avatar
    This is becoming WAYYYY to much of a pain in the butt
    Dec 2004
    Christiansburg Va
    why?-----once you see how easy it really is you will be glad you did it yourself.
    3500 watts of SQ!!
    Pu_DeKcUf is offline LX Newbie
    Dec 2005
    before you buy from crutchfeild check out www.etronics.com escpecially if you are lookin to save some money
    BluMag's Avatar
    BluMag is offline LX Padiwan
    Jan 2006
    Houston, Texas
    with the battery in the back, there is no readson to pay an installer, you will be fine!
    smokey0810's Avatar
    Well, I've done car audio stuff before in my old cars, but they were mainly complete installs...as in new speakers & headunit all around. This is different. I really don't want to screw this up and am super nervous about this one...hence the 1,000 questions.
    I am still a bit confused on what I need to complete the setup.
    1. Amp
    2. Sub
    3. Enclosure
    4. Line Out Converter...
    Which is where I am getting lost.
    ASU_Magnum's Avatar
    ASU_Magnum is offline I'll be back...someday
    Nov 2005
    Phoenix
    Basically with the line out converter, your going to splice into one of your speakers mid-line. Then your going to run the cable off the splice into a line out converter. From the line out converter, your going to run the RCA cable and plug it into the input on your amp. Then run the speaker cable from your amp to your sub
    What the heck is a line out converter? I never heard of these before I did my system either. A line out converter is basically a way to convert your raw speaker cable into RCA(like $10 at walmart), so that it can plug into your amp. On one end you connect the stripped ends of your speaker cable and on the other end is an RCA output. You may not even need this if your amp has Speaker Level Inputs. Not all amps have these though. My Alpine amp for my speakers does but my DHD amp for my subs didn't.
    Hope that helps
    2005 Magnum SXT Bright Silver - SOLD
    2006 Yamaha R6 Raven -STOLEN
    Quote Originally Posted by Zmagnum
    You are famous. You have the fat woman sittin' crack findin' Magnum
    allpont's Avatar
    allpont is offline LX Padiwan
    May 2005
    Upstate, NY
    I'm in the same position as "smokey"...It's great that there are guys out there willing to explain the little details to us that know how to do it, but want reassurance. And remember, there are members reading this, as I did ,that will use your advice, that will not post a response. So you are actually helping many other members by talking to just a few. It's all good.
    Dec 2004
    Christiansburg Va
    and as for the sub/amp/enclosure combo----make sure you look for a sub/amp combo that work well with each other @ the recommended ohm load----makes sure the sub/enlcosure works well with each other also----remember that larger enclosures need less power than smaller ones to get the same dBs.-----read the recommended enclosure spec and makes sure the enclosure you (buy or build) will work-----also are you going sealed or ported?
    Don't get caught in the "ported is booming" belief----a low tuned ported enclosure can sound just as good SQ wise as a sealed enclosure---if you need any help designing an enclosure PM me, I will help as much as poss.(same goes to everyone)
    as for the amp----look for a brand that is CES rated----in other words REAL ratings not "ILS"(If lightning strikes) strike ratings.
    3500 watts of SQ!!
