Results 1 to 5 of 5
    Muscle Shoals, AL
    Gauge Pillar Install
    NEED HELP!! I have a 3 gauge pillar pod for my 05 dodge magnum R/T n have had it for some time now (bout a year n a half) but never got around to hooking them up cause everyone I asked either didnt know how nor had the time so I'm tired of waiting. Could anyone please help me out, I dont even care if the gauges are functional, as long as they light up I will actually be happy cause its better than them just sitting there dark and in my way. They are glow shift gauges. Any help is very much appreciated -Chris (SBC)
    2005 Dodge Magnum R/T
    Work in Progress...
    www.SketchesByChrisM.com
    - My Car Art Website, please check it out!
    legmaker's Avatar
    legmaker is offline LMI Intakes....CF intakes for LX/LC
    orlando, fl
    chris - you can tap into the wire harness in the pillar for a switched power lead. grounding the gauges is as easy as tieing all the ground wires from each gauge together and using a small self tapping screw to the pillar. as for making them functional, it would depend on what they are monitoring as to how the sending units get hooked up. just get in the car, turn the key to the on position and take one of the gauges power wires and insert into the plug for the wire harness in the pillar until you find the wire that is 12v switched power. tap in there and you are golden........ no need to run power wires all over the inside of the car! lol
    FLXC President
    10.19 @ 135 mph PWR forged 6.1 w/novi 1500 s/c @17psi / AfterHours Mopar Perf. installed!!!
    Super T's Avatar
    Aurora, IL
    which gauges (what do they measure)? that's not an overly-complicated install, just tedious w/ the wiring. can't believe nobody local can help :-(
    Posted via LXFMobile
    typicalmarine's Avatar
    Jun 2007
    Maryland
    I know T, I was thinking the same thing! Looked at your location Sketches and youre a bit far from MD but chat with someone local to you so you can get this taken care of.
    Post pics when youre done
    fuzzycali's Avatar
    fuzzycali is offline Space City LX Nawfside AC
    SPRING,TX
    i ran my power to the headlamp switch and tapped it there.ground on the pillar.
    2007 Charger Road & Track R/T
