Mr charger john in the 07 owners manual turning off the seat belt chime was list under "Things to know before starting your car". Get in buckle up key in ign. Turn key on, wait for lites to go out after seat belt guy lite goes out then unbuckle and buckle up at least 3 times leaving buckled up within about 1o seconds and turn key to lock and a single chime will anounce. Now this in on the 07's. You have an 09 and probaly a "fancy" key fob. May not work on your 09 but you could look in the owners manual to see if there is a new way it is explained.
12.854 @ 106.73; 1.805 Sixty Foot; CMR Tune By AJ Hemituner, 3" Cal Hood, C&L CAI, Ported T-Body, Gasket Matched JBA Shorties Jet Hot Coated inside and out, JBA Hi Flo Cats, Stock Daytona Muffler, SRT8 Tailpipes, Reso Delete, 6-Speed Engine Mounts, SLP Underdrive Crank Pulley, Mopar TCM, Pro Torque 2800 Verter, SRT 3.06 Gears, 09 Chally Axles & Hubs, Hoosier 275/40/17 Drag Radials, M&H Skinnies
