Results 1 to 5 of 5
    Frankyoz's Avatar
    Frankyoz is offline LX Guru
    Dec 2008
    AZ
    Dynamat trunk kit question
    I just got my kit today and was wondering about any tricks or specific locations I should make sure not to miss. I want to definitly kill the spoiler rattle and since the actualy base of the spoiler isnt really accesible do I just line the shell facing the trunk, thanks.
    Mighty Noid's Avatar
    Mighty Noid is offline time to paint the car soon!!!
    Aug 2005
    SoCal
    Leave the dynamat in the sun for a few hours to make it go on easier...
    Use sometype of degreaser to wipe down the area's that you are going to do... this will make it stick better and last longer...
    Make sure that you use a roller to get out any air bubbles and it will have it to stick...
    Area's to hit with it... under trunk, side quarter panels, and spare tire well... if you have some left over... hit the bottom of the panel that holds the 6x9's...
    have fun...
    Thank you Bigal470
    Super T's Avatar
    Aurora, IL
    You don't have to cover every square inch with the stuff - you're targeting large flat areas of sheet metal that will vibrate and transmit / add to noise. If you have some left after you've hit those spots, then start filling in the gaps.
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    All good advise, that's how I did mine.
    Frankyoz's Avatar
    Dec 2008
    AZ
    All done sounds much better inside much deeper bass was my first impression, things are a bit quiter outside spoiler doesnt rattle but its just shown me that its underneath my car where I get most my rattles. Crawled underneath isolated one or two sounds but majority sound like its coming from places up inside the car between the crame and the body type stuff.
