Results 1 to 12 of 12
    Carmel, Indiana
    Are the big speakers on my doors only supposed to play bass?
    My speakers in the doors have only played bass since I can remember, anyone have any insight on why that is?
    Is it possible to wire a door speaker amp to these speakers so they play mids/highs... I have a subwoofer system and could use the louder mids/highs.
    Let me know!
    Ever since my avic D2 installation this has been happening, but can't remember back far enough to remember whether or not they played mids and highs prior.
    2-Tone Paint, Davin SS1 Floaters, UAS F.B.S.S. Digital Air Ride, Flashtech L.E.D. White Halos, Illegal Death HIDs, Grill, 90 lambos, Tinted tails, Avic-D2 Nav, DVD plyr, 7" Headrest Scrns, Eclipse Titanium 12s, 1300HCT amp, 12 Ferad Cap, Tint, Viper Alarm, White Grill Lighting, and more
    2003 Exploder 4x4 on 24's, 4 12" HCCA, 5000D amp, Flashtech halos, HIDs, Grills, screens, more
    1992 F250 4x4 w/ 351 Windsor (5.8) Plow truck with 84k miles
    GROUNDED's Avatar
    GROUNDED is offline My car is lower then your standards...
    Dec 2006
    wilbraham, ma
    Doors are midbass. You would need to hardwire your speakers to get around this.
    My car is lower then your standards _____
    Carmel, Indiana
    Quote Originally Posted by GROUNDED View Post
    would that mess up the power that goes to my other speakers?
    blindpig's Avatar
    blindpig is offline 2 S1OW
    Jun 2008
    Northern Virginia
    my doors & dash are wired to an amp with the dash receiving the highs and the doors receiving the mids.
    Carmel, Indiana
    hmm is that different from how the boston acoustics are wired from the factory? Call me dumb but im used to old POS cars
    gameover's Avatar
    gameover is offline voiding warranties
    May 2006
    New Orleans
    So you have the factory boston 6x9 still in place but just added subs and an amp right? If so, since you are just running the highs (door speakers) off the radio without an eq or crossover, it will play with the sound adjustments you made to the radio for the subs.
    For instances, to keep bass from coming thru the highs, the bass/low setting would be turn down on the head unit. But doing so, the subs are not beating because the setting is low. So I assume that you have the bass cranked a bit, hence the reason its coming thru the highs.
    If you do have a high hooked up, disregard the above. You might just need some adjustments to the radio and amp.
    05 RT . Jett Black . SRT Fascias . UAS . AFEII . Zoomers . Forgiatos . Wilwoods ...
    tank8289 is offline Supporting Vendor
    Jun 2007
    West Milford, NJ
    I have a question, i have a 4 channel hooked up to the doors and the rear deck speakers, im going to eventually do an amp to the tweeters in the dash, but why does the navigation sound muffled now. Disconnect the amp it sounds fine, hook it up the navigation speaker sounds muffled.
    392 Stroker, Builder Bill TC, Builder Bill tranny, LXAS LVLI Tcase, Novi 1500 10.5psi, 150 shot of nitrous, tuned by Josh @ HHP
    Carmel, Indiana
    Quote Originally Posted by gameover View Post
    No the subs are plenty loud with the bass gains all the way down, doesn't distort hardly at all.
    The problem is the speakers on my front and pass door only play bass, nothing else. I am confused about your last sentence though...
    Is there a way to fix this?
    gameover's Avatar
    May 2006
    New Orleans
    What are the highs hooked up to? An amp or off the radio? Also are they oem or aftermarket? Can you listed what you have installed in the car? I'm confused myself.
    Carmel, Indiana
    My door speakers only play bass. No mids no words no nothing. Just bass.
    The tweeters and rear deck speakers play mids and highs.
    I have a Pioneer Avic D2 powering the door speakers.
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    The factory BA 6 speaker system has the door 6x9's playing from around 200-250hz and down (guessing here on the exact frequency), the dash 3.5's play from 200-250hz and up and the rear 6x9's seem to run full range.
    2006 Dodge Magnum R/T - SC Flashpaq, Volant exhaust, 22x9 Challenger SRT8 wheels, 265/35/22, 14.1@98MPH
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    Major's Avatar
    Major is offline Death Before Dishonor
    Mar 2006
    Fort Belvoir, Virginia
    Are the speakers in the door OEM speakers or aftermarket? If you're running two 12s IMO it's a must to have an amp on your aftermarket mid/high speakers. The wattage from the HU is a joke. Your subs will drown your mid and high range speakers. My doors are converted to a 6.5 instead of the 6x9
    Quote Originally Posted by chargerondavins View Post
    Buy aftermarket speakers.
    Zenetti|E&G|AFe|BilletTech|Alpine|JLAudio|ImageDynamics|Focal|CarbonbyDesign|Katzkin|Eibach|Koni|DiabloSport|Borla|spec.dock|HIDs
