Results 1 to 7 of 7
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Best way to route hi amp power cabling from battery to dash
    I know some of you have run auxillary power from the battery area up into the front of the cabin. Any pics on how you routed it, what you had to removed to get it through etc?
    Any help would be appreciated!
    Thanks,
    Don
    Super T's Avatar
    Aurora, IL
    I would pack it into the lil cable tray w the stock 4ga that feeds the front pdc, that way it's protected... otherwise i've gone under door trim all the way through cars multiple times w a few thousand watts (stereos).
    Posted via LXFMobile
    Maistro69 is offline Obama SUCKS!!!
    Nov 2007
    Certified liberal hater
    ^^^ Prob the best way to run it. I ran all my speaker wire down the driver side as I usally like to keep power and sound as far aprt as possible. Most of the trim pieces come out fairly easy and just snap in. The only place you'll need a philips screwdriver is for the panel beside the rear seat and the B pillar trim piece. I've got a handful of wires routed through there for speakers, gauges, and lots of spares so theres adequate room to run whatever.
    I'll keep my money, guns, and freedom, you can keep the change.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Can I use this route without pulling any seats or carpeting completely out of the car?
    Zoban's Avatar
    Zoban is offline lil Red Wagon
    Feb 2008
    Oshawa Ontario
    The drivers side trim route you shouldn't have to pull seats or carpet .. just the rim yer tucking it behind.. I've seen it just shoved up under the trim by people and it "works" but I suggest taking the couple mins and pull the trim it's not that hard..
    2006 Lil Red Wagon SXT
    Modlist : AFE Stage II, JBA Headers, Corsa Catback, 20" Vipers, Cross Drilled Rotors, Diablo Bob@SVS Tuned, Pioneer DEH-5000UB, 12" Enclosers, Halos, Low/Fog HIDs, Cuda Grille, TruFiber Chally Hood.
    at the Track
    My Garage
    Mentoria Computer Consulting
    FloridaRT's Avatar
    Ocala, Florida :-)
    Quote Originally Posted by GasGunR View Post
    Thanks,
    Don
    Why not use the battery terminal that is under the hood near the fuse panel???????
    Should be easy to run a cable from there into the passenger compartment.
    That cable is powered by the battery in the back............
    Bob
    Bob in Ocala, Florida (a 73 year old guy who loves cars), 05' Magnum RT. Many mod's, all of Danko Products and a few from 402 Motoring.
    Have owned my share of 12 & 13 second cars, am happy now with my stock RT.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    ^^^ cause it isn't designed to add a bunch more stuff to it Hence the additional cable
