Results 1 to 7 of 7
    vinny68's Avatar
    vinny68 is offline VINNY68
    May 2006
    Central Illinois
    Anyone ever fixed a "Disc Error"?
    I am getting the dreaded "DISC ERROR" on the CD changer of my NAV system (not the NAV DVD, just on the CD changer). Has anyone ever been able to fix this condition without spending hundreds of dollars to ship it off somewhere? I've tried disconnecting and reconnecting the battery and disconnecting and connecting the connections on the back of the unit. Any other suggestions? This is very frustrating.
    fnkychkn's Avatar
    greasy cardboard box
    have you tried a different CD. a store bought one, not a home burn?
    hawkxp's Avatar
    hawkxp is offline Supporting Israel since 1948
    Portland OR
    One of the semi-known issues is overheating with some of the earlier REC models.. IIRC that it seemed to happen more in the winter when the heat was running behind the head unit.
    Is it every disc? Only when the car has been running?
    Is your 2006 still under warranty?
    What would the US do if Mexican Drug lords lauched rockets from Tijuana?
    vinny68's Avatar
    May 2006
    Central Illinois
    It's a unit that I just bought and installed. I haven't been able to load any discs yet. When I hit the LOAD button plus one of the numbers, it sounds like it cycles through 3 or 4 trays but then stops and the screen says "DISC ERROR". It won't let me insert any discs into the changer.
    fnkychkn's Avatar
    if you just bought it used and had it shipped to you, the changer mechanism may be damaged. there is a special shipping braket that needs to be installed for shipping. did yours have this when you got it? if not, you may have just bought a brick.
    vinny68's Avatar
    May 2006
    Central Illinois
    I wouldn't go that far. The NAV feature works great and the radio still works too. I found this place http://www.videoservicestop.com/gps/index.htm that claims they can fix it, although I haven't figured out a price yet.
    Does this bracket you refer to have a part number so people can order one or does it only come with new in-the-box units from the manufacturer?
    fnkychkn's Avatar
    that's the only place i've ever seen them. although, i installed one today (brand new, not refurbished) and it did not have this braket or even the slots to insert it. maybe they changed the design so that it's not required anymore???
    i'd check with Mr. iNCREDIBLE. he's had many of these apart and may be able to help.
    good luck
