Results 1 to 4 of 4
    SV Cat is offline SV Cat
    Sep 2007
    Sierra Vista, AZ
    AMP Install Help
    Hey all,
    Need some of your help...I recently installed a second AMP. The first AMP is a 4-Channel with the second a 2 bridged to power a sub. Prior to installing the second AMP, I was powering my 2 rear deck Polks with two channels. When installing the 2nd amp, I decided to power all four 2 front door and 2 rear deck speakers by pulling the H/U out and tapping into the speaker wires. I double & triple checked to ensure that all the wiring is correct. My issue is that I currently have only my right side speakers powered and working fine. The left side has very low volume about 1/8 of the power. Can anyone tell me what I might have messed up?
    The fade works fine, I've already rewired twice and same issue.
    SV Cat
    Super T's Avatar
    Aurora, IL
    what radio do you have that you tapped into the wires off of?
    Sep 2007
    Sierra Vista, AZ
    H/u
    I have a factory radio, I cut the appropriate wires and wired the signal & speaker wires from there. The signal leads to a LOC I have installed. From LOC to AMP.
    SV Cat
    Sep 2007
    Sierra Vista, AZ
    Anyone have any alternative trouble shooting ideas?
    SV Cat
