Results 1 to 8 of 8
    IZAMAG05's Avatar
    IZAMAG05 is offline LX Padiwan
    Jan 2009
    DETROIT, MI
    Amp bridging?????
    When bridging a 4 channel amp, does this mean you'll only be able to run it in mono, or can you still run it in stereo hi/pass? i.e. components...
    Maistro69 is offline Obama SUCKS!!!
    Nov 2007
    Certified liberal hater
    How are you bridging it? Are you bridging front 2 channels for 1 output and rear for 1 output? If so you can still use it as a stereo amp and the hi/pass should all work just the same. Somewhat depends on the amp as for combination
    I'll keep my money, guns, and freedom, you can keep the change.
    IZAMAG05's Avatar
    Jan 2009
    DETROIT, MI
    it would run a set of comps up front, is that possible???
    Mighty Noid's Avatar
    Mighty Noid is offline time to paint the car soon!!!
    Aug 2005
    SoCal
    You can bridge channels 1 & 2 for the right front speaker and then channels 3 & 4 for the left front speaker.
    Thank you Bigal470
    IZAMAG05's Avatar
    Jan 2009
    DETROIT, MI
    thanks cool!!!!!!!!
    bigal470 is offline LX Guru
    Nov 2006
    San Marcos, CA
    what brand amp?? remember not every amp is the same if you hook it up wrong you can blow out the amps output circuit
    New Ride In the Making! Like it on the Book and watch the build progress
    gooeytek's Avatar
    gooeytek is offline heavy hemi
    Jun 2008
    Lake Grove, NY
    it wont be stereo.
    http://www.lxforums.com/board/signaturepics/sigpic23029_3.gif
    MY HEMI REGISTRY PAGE
    ... Do it for fun and enjoy the improved performance, but don't think you made a transaction that makes any financial sense. Use the economy numbers to torpedo the tree hugger who wants to get snooty with you, but know in your heart you did it so you could go faster.
    Aug 2005
    SoCal
    Quote Originally Posted by gooeytek View Post
    it wont be stereo.
    Yes it will be... you would feed the left signal to channels 1 & 2... then you send the right signal to channels 3 & 4... you will have to use "Y" cables but this will still give you stereo image.
