Alternator Whine
I know this may have been addressed, but I did a search and did not get much so here it goes.
I just re did the audio system in my charger and as with most american cars I have worked on, I get the dreaded alternator whine. I checked the ground at the HU and it is secure with a 4.2ohm resistance. This should be acceptable. I then checked the amplifier grounds, initially I got 138-160ohm reading, so I moved the grounds to a different location and now I get roughly 8ohms, this should be acceptable as well.
The one thing I did notice, I cut the ground at the harness, and never lost power to the deck. I removed the antenna cable from the HU and that shut it off. I also found that if I wiggle the antenna lead coming from the HU, it does cause the deck to flicker on/off. I think this might be the culprit. The other thing I think might be an issue is the crappy RCA cables I am using. I will purchase 2 more sets of a twisted pair and try that.
I did try to move the ground of the HU to another locaion and got no result as well, and still end up with a roughly 4ohm resistance.
FYI my system consists of RF amps, Clarion HU, and all Polk Momo series speakers. I am running 4ga wire to each amp, grounded by 4ga wire as well. Each amp has its own run of B+.
Any thoughts, suggestions, would be great. I haven't installed for over 8 yrs, and I used to be the go to guy for getting rid of noise. This one is trumping my knowledge pool. Please help and thank you in advance.
God created Paramedics so Firefighters and Police Officers can have Hero's.
