Hi does anyone know why my passenger airbag light is on and is there anyway for me to cut ot it off
If no one is sitting in the passenger seat and the airbag light is on you need to take it in for service. There is a load sensor under the seat that determines when to enable or disable the air bag. No one in the seat, disabled. Someone small in the front seat, disabled but a warning light is on. Regular adult, airbag is enabled no indicator light.
There is a calibration procedure that the dealer will need to do in order to get it set right.
2005 Dodge Magnum R/T
-Martin Luther King, Jr.
ok thanx now for my next question
When i use the U-connect the speakers static but on my phone i have an full antenna but on the navi screen theres not a bar...Can this be corrected
Here's how the passenger airbag light works -
1) ON - bag is OFF, no one is sitting there... if there is then they should weigh less than 50lbs (like a child, not a good idea)
2) OFF - someone (or something) heavier than 50lbs is on the seat.
My light was not initially working correctly. After some work on the front-inside mounting bolts (the horizontal bolt is the mount, the vertical is the "adjustment") it now works correctly.
Mines been comming on, and it is really annoying, lol.
I just need to visit service... Cant find the time to take it down there...
Mopar Parts, Accessories, Performance.
Jason Evans
www.MoparStore.com
Phone: 800-839-3660
Hours - 8-5 Pacific time.
If you're comfortable with (and have some time, not a lot is requried) you can make the adjustment yourself. I had initially made mine by mistake, and after realizing it I had played with the adjuster and understood how to make the adjustment myself.
