ANy one done an aftermarket deck yet i have and the acc wire is not 12 volts so i hard to tie it in with the coinstant which mean i have to make sure i turn the radio off when i leave the car just wondering what anyone else did???
I am not sure what source you used but if you want it to be only on when your iginition is on just move the fuse to the other slot. The fuse panel has three slots. One is common, one is power on all the time and the other is power on with iginition.
2005 Dodge Magnum R/T
-Martin Luther King, Jr.
huh??? im little conffused are u talking about the fuse for the radio in the trunk i just ahve it wired with the constant for now
Sorry got magnum on the brain. :oops:
But some of what I said still holds true. You can change whether a power source is constant on or just on when the key is on by moving its position in the fuse panel.
I've installed quite a few stereos in my past cars, and FROM what I remember, its the remote wire that makes the stereo turn on and off . Someone please correct me if I'm wrong.
I miss my Maggie
the remote wire is an output FROM an after market stereo that sends voltage to an amp or power antenna or both to cut them on when the stereo is turned on. More than likely if the fac. stereo does not not have a 12volt switched wire you can use a relay along with a hot wire and create a 12 volt switched lead.
I just got my magnum yesterday but I do plan on upgrading the stereo (the Boston Acoustics sucks ass!!) I don't think it is on a DATA bus type system but I am not sure
Hope this helps
Thanks for the Avatar, Hazman
Mine:
Hers: :downboy:
Mine::twisted:
51 Chevy pick-up
http://www.soundsweet.com
The factory stereo is powered by a single 12V power wire. There is no ignition switched 12V wire. The radio and amplifier are turned on remotely through the CAN-BUS system.
You can get a switched 12V signal FROM a switched accessory plug.
from what plug?? how bout just running it to the cig lighter fuse?
The Magnum radio is on a can-bus type output so using the existing wires FROM the radio is a no go but the amp is pretty close/ I am in the process of installing a Kenwood 7015 dvd/cd/touchscreen with navigation so far it looks like it should be fairly simple to do just a slight modification of the dash trim/ I don't think I will miss the wheel controls. I harly use them now .Originally Posted by Earcandy
Mine:
Hers: :downboy:
Mine::twisted:
51 Chevy pick-up
Hey Earcandy, I want to install the same Kenwood head unit, but two places told me it wouldnt fit even if they trimmed the dash piece!! Im thinking it will fit. Are we talking about the regular radio or the nav opening?i have the regular radio. If it fits let me know how you did it and if you can take some pics. Thanks and good luck
I know its a little late http://www.dodgemagnum.net/phpBB2/viewtopic.php?t=2445Originally Posted by msauer
Mine:
Hers: :downboy:
Mine::twisted:
51 Chevy pick-up
The adapter for the '04 durango fits the magnums with the reg radio. I ran the ignition wire FROM the head unit to the lead of the cigerette lighter. You will also need an antenna adapter. Here is my install http://members.cox.net/david.a.heath/
