Results 1 to 15 of 15
    Nightstalker is offline LX Padiwan
    Mar 2008
    milwaukee
    Adding subs to factory rec nav?
    As it says,just wondering what's parts I need to add a amp!
    Anybody that might have part numbers might help too.
    I'm just looking to add subs but keeping factory system!
    diboblo's Avatar
    diboblo is offline Just a guy with a car...
    Dec 2007
    Riverside, California.
    You will need the following:
    Sub
    Box
    Amp
    C2A-CHY (pac-audio)
    1 pair 15' long RCA's
    1 stranded 14ga 15' long wire
    The pac-audio box plugs in behind the REC and gives you two pair of RCA's, plus a 12v switched remote turn on wire.
    Remove your console and run the RCA's and remote turn on wire to the trunk.
    Install your amp, box and sub in the trunk and hook up accordingly.
    It's pretty easy on these cars.
    I will caution you NOT to get a basic LOC for this application. They are cheaper, but the sound reproduction is muddy and prone to roll off at higher volume levels, when compared to the C2A-CHY.
    Keep in mind that you will not have bass control from the REC HU to the sub(s). Most mono block amps have a remote gain control that you can run to the dash, anyway.
    Hope this helps.
    Now tuned to Raise Hell!
    Interior Lighting Color Change Mods!
    Mar 2008
    milwaukee
    Ya that helps if I have lockpick do I still need all those parts!
    rmart06srt8's Avatar
    rmart06srt8 is offline cruising the RGV in SRT style
    Mar 2010
    RGV, TX
    this is good info. i am also looking into adding a sub to my car. one question, where can i get the C2A-CHY (pac-audio)?
    2006 Chrysler 300C SRT8
    mods: BT Park Lockout Mechanism, CAI, Hoen 'Endurance' Foglights, PCV Catch-Can, Rear-Reso delete, 275/40r20 tires, StopTech Cross-Drilled rotors w/ StopTech Pads, more to be added....
    04 Dodge Ram RC/SB Hemi - SOLD; 01 VW Jetta GLX VR6 - SOLD; 95 VW Jetta GLX VR6 - Crashed/SOLD; 86 Dodge Ramcharger - SOLD
    diboblo's Avatar
    Dec 2007
    Quote Originally Posted by razcharged View Post
    Yes, the C2A-CHY is a stand alone device and has nothing to do with your lock pick
    diboblo's Avatar
    Dec 2007
    Quote Originally Posted by rmart06srt8 View Post
    I've found the best price for this little black box on eBay (about $78), sometimes with free shipping!
    Retail is around $99.
    If you want to go direct, you can get it from Pac-Audio, or any good stereo store... Just don't let them sell you some cheap piece of junk and tell you it is the same thing. If they don't have it, move on.
    ...:SRT8:...'s Avatar
    ...:SRT8:... is offline LX SuperBee
    Sep 2009
    Auburn, Washington
    Audio Control makes some good stuff too.
    ****Click here for the Superbee Owners Group****
    .......: 2008 Charger SRT8 Superbee 534/1000 :......
    "..IF IT WON'T FIT, FORCE IT, IF IT BREAKS...IT NEEDED TO BE FIXED ANYWAY..."
    Mar 2008
    milwaukee
    Thanks again brothers!
    Knightrider's Avatar
    Knightrider is offline LX Padiwan
    Jun 2008
    Houston, TEXAS!!
    In all reality you do not have to touch the dash. I spliced into the rear speakers for my setup with an in line converter. That way you can adjust the sub level with out taking dash apart or having to rig something up to access the RCA adapter. Just a thought.
    This is the part mentioned above
    http://www.pac-audio.com/productDeta...&CategoryID=28
    The In-Line Converter I used
    I'm not sure if his Magnum will fit in my parking space.
    2008 Magnum R/T, Brilliant Black
    2011 Durango Citadel, Brilliant Black (as of 3/12/11)
    Rommelrommel is offline LX Newbie
    Feb 2010
    Quote Originally Posted by Knightrider View Post
    The rear speakers are not full range in most setups, and the C2A is far superior as it gives you a remote turn on, and takes full range signal directly off of the CANBUS. A LOC might be a good solution for a base model car with the 4 speaker setup.
    06BlackR/T is offline LX Padiwan
    Mar 2009
    Mass
    With the C2A-CHY I know the signal going to any amps off the RCA's is a raw signal and the bass/mid/tremble on the radio don't work, but does it effect the signal going to the factory amp as well? Basically if I am only adding an amp for a sub and leaving all the other speakers off the stock radio do I also lose control over the stock amp and speakers?
    diboblo's Avatar
    Dec 2007
    Quote Originally Posted by 06BlackR/T View Post
    You will not lose any other functionality. Only the signal to the new amp will be null to any adjustment, but if you run an amp with bass boost, you can control it that way.
    Mar 2009
    Mass
    Quote Originally Posted by diboblo View Post
    Great thanks, that is what I thought but it isn't real clear in all the threads I read through.
    mlgreen's Avatar
    mlgreen is offline LX Padiwan
    Milwaukee, WI
    Thread resurrection! I have an 06 with the oem Boston Acoustic system and a mygig with lockpick. I plan on replacing the B.A. setup with oem kicker speakers along with the oem 368 watt digital amp so I'll need a sub for the low end. Is this the Pac interface I need for adding an aftermarket sub and amp for an 06 with mygig and lockpick?
    Sent from my PC36100 using Tapatalk 2
    moaugust88's Avatar
    moaugust88 is offline I'm up all night to get lucky!
    Nov 2009
    Chicago
    Yup it will plug inline with the lockpick to the radio.
    2006 SRT 300C R2C
    CAI and a ton of mods...
    Quote Originally Posted by fatchance
    You take a four-door sedan and make it a rocket ship.
