Results 1 to 9 of 9
    96GTS's Avatar
    96GTS is offline LX Guru
    Mar 2009
    SoCal - 562
    12V ignition on source in engine and trunk?
    Dont feel like touching every wire with a test light, then turning car off and repeating. So does anyone know of any ignition switched 12V wires both under the hood and in the trunk? Thanks in advance!
    2008 Charger SRT8 (8.26 @ 85.45) - (12.95 @ 108.90)
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    Quote Originally Posted by 96GTS View Post
    If you don't get an answer here, send a PM to fnkychkn--this is the kind of stuff he'll probably know.
    ekaz is online now all gone
    Jun 2006
    CHICAGO
    you can use the fuse for the cigarette lighter in the trunk, not sure which is switched under the hood
    Unlawful Gathering
    Click for details!
    2009 MBP GCSRT8
    Powered by PWR
    Shifted by SHR
    Tooned by Johan
    Blinged by Billet Technologies
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Quote Originally Posted by ekaz View Post
    If I'm not mistaken the OP is asking for a wire that is Key On Engine Running (KOER) as opposed to Key On Engine Off (KOEO); hence the reference to ignition. I maybe wrong, but I'm not sure the cigerette lighter fuse/wire would qualify.
    96GTS's Avatar
    Mar 2009
    SoCal - 562
    The instructions call for "IGNITION SWITCHED 12 VOLTS". The one in the trunk is for a bottle warmer. I'm assuming that would be KOEO so it can warm in the staging lanes. What fuse is the cig lighter in the trunk?
    diboblo's Avatar
    diboblo is online now LXHarness:Custom light mods & Harnesses
    Dec 2007
    Riverside, California.
    Send a PM to Raymond (PLCMAN). He has designed a very robust 12 Switched Power Supply for the LX platform.
    Check it here: 12 Volt Switched Power
    Bob
    Here's a pic:
    Now tuned to Raise Hell!
    96GTS's Avatar
    Mar 2009
    SoCal - 562
    Looks cool and he does good work, but that's a little intense for what I need. That is along the lines of what's going in my race car as I am wiring that from scratch. I don't need that many outputs on my Charger. I have no big stereo or lights. Just a small nitrous system.
    diboblo's Avatar
    Dec 2007
    The cigarette lighter in the dash is switched 12 power, controlled by the key.
    Here's a writeup on how to tap into that.
    In the trunk, the fuse is number 18, and you can tap off of that for switched 12v (low current (see the fuse rating for max current on this circuit)).
    In the picture below, fuse 18 can be either in line with the rest of the fuses (constant 12V), or offset for switched 12v.
    Hope this helps,
    Bob
    Player87 is offline LX Newbie
    Nov 2009
    Germany
    just want to ask again.
    where can i get a wire under the hood which is controlled by the ignition.
    If the ignition is on the wire should be powered.
    if the ignition is off the wire should have no power.
    is there any cable like this?
    thanks
