    Mr. iNCREDIBLE's Avatar
    Apr 2006
    *sigh* I need some help....
    my radio has been in and out of my 300c couple of dozen times...
    this past time it appears the antenna connector for the AM/FM radio finally broke...
    where can I find a replacement? or and extension that I can crimp onto the OEM Coax?
    I've checked Radio Shack and some local stereo shops with no success and I don't want to run a new antenna all the way from the rear just because the plastic collar broke off...
    Mighty Noid's Avatar
    Mighty Noid is offline time to paint the car soon!!!
    Aug 2005
    SoCal
    Is this what you need??
    http://www.scosche.com/scosche_carau...2&ItemID=CRARB
    you can cut this one up and solder it onto your factory wire
    Or this one...
    http://www.metraonline.com/products.aspx
    Thank you Bigal470
    Apr 2006
    thanks Noid, that will work.....
