Page 2 of 6 FirstFirst 1234 ... LastLast
Results 16 to 30 of 76
  1. #16
    MikeEast's Avatar
    MikeEast is offline No longer sporting dual R/T's!
    Ducktown, Georgia
    Did it here too - two different pc's and a plethora of browsers (browsi?)
    I gave up and minimized this one (chrome) and later I opened it up and magically I'm in. WTF?
    I'm not all that distressed though, I'm thinking that this is just another symptom of the lowering of standards that seems rampant these days. I always thought that computers/networks/software was supposed to work the first time, every time, or else it was broken. Apparently that's gone down the tubes just like corporate responsibility.
    These days it seems there are numerous examples at work where you have to try three times (repeatable too!) in order to get an application to talk to you. I persisted one day and walked a symptom as far up the hill as I could get and ended up with a 'That's just the way it works' answer.
    Oh well...
    Mike
  2. #17
    Redfox0099's Avatar
    San Antonio, Tx
    I log in and it says thanks for logging in but it takes me back to the screen where you can log it.
    BUT I can click on the LX banner at the top of the page and it goes to me being logged in
    Been that way for 2 months now, no problems with mobile though.
    Posted via LXFMobile
  3. #18
    markus's Avatar
    markus is offline whats up with it vanilla face
    Northern VA
    Quote Originally Posted by Redfox0099 View Post
    me samesies
  4. #19
    WitchyWndy's Avatar
    WitchyWndy is offline Pouting, sniveling and whining :D
    Dec 2007
    Northern, Ohio/Upper, NY
    Had to log in today, as well.
    2007 SubLime || #1035 || Mods: Arrington 440 ci stroker, 90mm TB, roller rockers and custom 5 pt rollbar, American Racing headers and catless mids, Paramount 8.8 differential, 5K Dominator Converter, drive shaft, DSS 1400hp axles, Transmission built by Enhanced Transmissions, SRT Corsa Catback, LMI prototype headlight CAI, Lots of BT goodies, "Show and Go" install package by BFNY Performance, Tuning by JerseyBoy
    1/4 Best - 4/26/13: 10.58 @ 128.47 2
    011 Atco Vid, Thanks RobAGD: Wheels Up!
    '06 Charger, Magnesium Pearl RT - My awesome DD
    RIP nhDave - Never forgotten
  5. #20
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    You do need to clear any cookies for lxforums.com and www.lxforums.com
    You can do them individually if you want, instead of clearing all cookies. In Windows XP, it's c:\Documents and Settings\User\Cookies
    find anything that's user@lxforums.com or user@www.lxforums.com and delete those.
    User in this case is the name of the Windows User - not your lxforums user name.
    Hope that helps, but if it's easier to just clear all cookies, you can do that with less effort from within your browser itself.
    - Click above for my HEMI Registry page -
  6. #21
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    Quote Originally Posted by WitchyWndy View Post
    x2
    -Ryan
    <<<clicky...
    '93 1500 SB - 240k, '05 Magnum RT - 18k, '80 El Camino - 86k
  7. #22
    plcman's Avatar
    plcman is offline Cheesecake Maker....
    Nov 2005
    Jacksonville,Fl.
    Mine works fine I had to log in just once.
    R.I.P LOU1355
    2006 Charger R/T R&T - Ordered 9-06-05- Home 12-23-05 - Mods: SRT Hood, 180 Degree Thermostat, JBA Shorties, High FLow Cats, SRT Suspension, AFE Stage II CAI, ---Painted Half covers --- AMG Paddles--Jaak Hack direct wire--PLCMAN Line-Lock board SLP Line Lock ---raymond@plcmanguy.com
    FLXC.ORG ---North Chapter Coordinator---Hemi Registry # 00648 plcman Maker of Cheesecakes... Thanks Billet Technology 2008 Shindig winner under the hood goodies!
  8. #23
    ResumeSpeed's Avatar
    ResumeSpeed is offline LX Padiwan
    Allover, Theplace
    Quote Originally Posted by NC-SXT View Post
    Yup cleared my cookies...yada..yada..yada. I havent done anything different. LX is the only forum that does it. Internet explorer 8 . 32 and 64 bit both does it. Anyone else? Or is it just me.
    I've been fighting the same issue for quite some time and so far have not been able to find a solution. For me it's not only this forum but several other forums as well (but not all forums).
    It all started when I upgraded from IE6 to IE8. It has something to do with IE8 (or perhaps starting with IE7 based on what others with the problem have stated).
    Clearing cookies, cache, and all of the other endless "tips" that I have run across has not solved the issue. There are a lot of people on the net having the same problem. Sometimes the log in will be remembered for a day or two, sometimes only for a few minutes, sometimes for a few hours.
    I thought that since it was happening on selected forums that it might have to do with all the advertising that some forums have added.
    I got so tired of having to constantly re-login that I simply uninstalled IE8 which reverted me back to IE6. Viola! Solved, no more log-in issues. At work I have left my computer on IE8 for additional testing, sure enough still have the problem there.
  9. #24
    plcman's Avatar
    Nov 2005
    Jacksonville,Fl.
    I am running IE8 no problems here.
    What security settings are your running and are you running AV software?
    I don't use any AV software I am my own virus detector.
    My settings are set to Med-high try resetting to the default setting.
  10. #25
    DMAG's Avatar
    DMAG is offline This Space for Sale ... Cheap
    Feb 2004
    New Yawk
    Also, you may have to login to both http://lxforums.com and http://www.lxforums.com
    That should clear any issues up.
    Anthony
    Follow Me on Twitter! | Knowledge Base | Search | LXOM Winners
  11. #26
    Allover, Theplace
    Quote Originally Posted by plcman View Post
    I have tried it all, countless hours spent, changed every possible setting. 10+ years on forums with all kinds of different computers and software configs, never an issue until I upgraded to IE8. A Google search will find tons of people with same problem and no solution found so far.
  12. #27
    crazy_luck's Avatar
    crazy_luck is offline I know where Hoffa is...
    Belle Plaine, MN
    I'm using IE8, and have been for a while with no issues. The only time it logs me out is if I kick my powerstrip under my desk and I restart my computer...
  13. #28
    Hemi Family's Avatar
    Hemi Family is offline Life is good
    Mar 2008
    Vacaville, CA
    Ditto first thing this morning...on second test worked fine
    Mopar CAI * Diablo Predator * CMR Tune * Magnaflow cats * Corsa exhaust * 180 tstat * HHP Stage II Pkg. * Shaved emblems/moldings * Rear Wiper Delete * Tint * Polished wheels * MyGig w/TV & NAV 2 Go Lockpick V2 * Backup camera * Pioneer AVIC-Z110BT * Hertz Audio speakers/amp * (2) JL Audio sub & stealth box * Hidden hitch * Remote Start * Auto Headlamps * Halos * BT Under hood kit, Catch Can, Pistol Grip Shifter * Slotted Rotors * AMG Paddle Shifters * Hotchkis Sways * BCR Coilovers * Pedders Track II * Next; More Track days and a Z06
    Her Him
  14. #29
    Rambit's Avatar
    Rambit is offline LXForums
    Quote Originally Posted by Junior View Post
    I didn't want to clear all my cookies so I wouldn't lose all my banking card numbers etc., but with Windows Vista the Cookies folder is not accessable through Window Explorer.
    You have to do it by going into Internet Options either through the Control Panel or IE's Tools menu and selectively delete cookies that way. On the General tab look for Browsing History, click on Settings and click on View Files. Cookies are amongst other files in there.
    That's the only way I was able to get back in and I didn't have to close & reopen my browser BTW.
    Bernie
    2005 300C SRT8 - #72 of 252 (excl. 11 pilots) - #10 of 35 Canadian SRT8's built
    2008 Harley Davidson FLSTF Fatboy - Vance & Hines Big Shots STGD with FuelPak tune.
    2008 Jeep GC SRT8 - Custom Build/Custom Delivered by SRT - 1 of 1 in Canada
  15. #30
    sound&security's Avatar
    sound&security is offline NOT MADE IN CHINA!
    Aug 2007
    FT LAUDERDALE
    Me too! Been going on for weeks
