WHEEL FIT
I just saw an SRT-10 truck. Good lord, those 22" rollers make me drool!
Is the bolt pattern the same as the Magnum and would they fit?
I doubt it.
- My Website - www.E55AMG.com
- 2002 Mercedes-Benz E55 AMG
- 2005 Dodge Magnum RT Hemi
- 2005 Chrysler 300C Hemi
You doubt the pattern is the same or that they can fit up underneath the car, or both?
I don't know the specs for the Truck. I based it on this fact - there are no aftermarket wheels at tirerack.com nor tires.com for the SRT-10 truck. They must be very unique. There are a number of wheels for the Chrysler 300 and if the truck wheels and the 300 wheel were interchangebable or similar there would be some wheels listed for the truck.
I wouldn't count on making those SRT-10 wheels work. I am pretty sure they are the standard Dodge Ram 5 on 5.5 bolt pattern. I am also fairly certain that the Magnum uses the smaller Dodge 5 on 4.5 bolt pattern. This plus the width of the truck wheels will make running them very prohibitive. To run them you would need to run adapters (not an optimum situation) and the wheels would stick WAY out.
Your best bet is finding a similarly styled wheel FROM the aftermarket with the proper fit for the Magnum.
Good Luck in your search.
RTon20s
- You may not post replies
- You may not edit your posts
Forum Rules
