Page 3 of 9 FirstFirst 12345 ... LastLast
Results 31 to 45 of 128
Like Tree27Likes
Thread: Weight reduction factoids ...
  1. #31
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    Actually it was the Hotchkis sway bar, lol. Good catch.
    Quote Originally Posted by 06HotRod View Post
    I'll be posting all this info in the 2nd post when I get a chance
    I've taken whats in this thread and split it into 3 catagories Interior, Exterior and Wheels and will seperate stock from after market in each one.
    This is the scale I got
    TL-440-Industrial-Hanging-Scale
    Dan can I list your sway bar as.......SRT sway bar only?
    9.18 @ 150 mph
  2. #32
    ponch79's Avatar
    ponch79 is offline LX Padiwan
    Mar 2010
    utah
    Quote Originally Posted by ponch79 View Post
    I just took off the AC lines and stock condenser & AC motor w/ pulley. I know they took some weight off. I'll get a total weigh and post it
    AC motor alone was 14.5 lbs the condensor was another 10lb and all the lines =25lbs
    Now to get rid of the entire back seats
    UNDER CONSTRUCTION
  3. #33
    budoboy's Avatar
    budoboy is offline Lightness is my power adder
    Feb 2006
    25 lbs for just the lines or do you mean 25 for everything?
    First all motor LX in the 9's
  4. #34
    ponch79's Avatar
    Mar 2010
    utah
    25lbs for everything, lines,ac motor w/pulley, condensor.
  5. #35
    budoboy's Avatar
    Feb 2006
    Cool, nice weight savings
  6. #36
    06HotRod's Avatar
    06HotRod is offline Maybe next year?
    Dec 2006
    LI
    Quote Originally Posted by FlyByU View Post
    That was my second guess! I remember you wanting to get the rear sway bar off and it was red.
  7. #37
    06HotRod's Avatar
    Dec 2006
    LI
    Second Post updated with all info except first post
    I still need to weigh my wheels thats why its blank
  8. #38
    BuckeyeGuy's Avatar
    BuckeyeGuy is offline This could get ugly
    Nov 2011
    N.E. Ohio
    Nice post Damon.
    My car weighed 4277 at Bradenton and I have stripped out most everything that can come out without pulling up the carpeting. I gained a couple of pounds going from the 5.7 to the 6.1 and from the stock exhaust to the Corsa. I am hoping to be right around 4100 at Va.
    Your list is missing the spare tire/wheel and jack assembly weight. For the magnums, there is also the cargo curtain, luggage tray and spare tire cover, which all add up.
    366CID 6.0L NA
    Designed and assembled by Arrington - Heads by GTP
    Installed by Novawagonmaster and me. Tuned by AJ and Matt.
    Franks Custom Cam, Kooks LT's, Enhanced Transmission, Paramount 8.8 w 4.56, DSS CF shaft,
    CTP, Custom Headlight Intake, FTI 4000 stall, Sunoco E85R
    10.974@121.54mph 1.45 60ft. @ 4100lbs
  9. #39
    FlyByU's Avatar
    May 2006
    Long Island, NY
    Well I was very suprised, I have taken everything out of my car but the paint, granted I am not skinny by any means but I still come in at 3970 lbs with driver and 5 gallons of gas. My car has nothing in it, 10 pt cage doesnt help but come on, wtf, lol. The 8.8 rear and stout drive shaft arent light but I really was hoping to get my car down to 3800 with driver without using a saw, lmfao.
    slideway likes this.
  10. #40
    JTSRT8's Avatar
    JTSRT8 is online now LX Guru
    Sep 2011
    South FL
    Big car. Lots of metal. How much did you shave off total?
  11. #41
    FlyByU's Avatar
    May 2006
    Long Island, NY
    500 lbs roughly
  12. #42
    Srt_Driver's Avatar
    Srt_Driver is offline LX Guru
    Apr 2010
    Chicago,IL
    Thats why u buy a evo 9,strip it down,put some basic bolt on parts,30psi..2800lbs and 10s all day long
    Sent from my DROID4 using Tapatalk 2
    *New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed
  13. #43
    06HotRod's Avatar
    Dec 2006
    LI
    list updated with *
  14. #44
    FlyByU's Avatar
    May 2006
    Long Island, NY
    10's arent good enough
    Quote Originally Posted by Srt_Driver View Post
  15. #45
    mark83 is offline LX Padiwan
    Jul 2010
    Norfolk, VA
    It would be interesting to see if some of the Mercedes sub-frame and control arm pieces that are Supposedly made of aluminum would drop the weight of the car significantly... Might be a good alternative compared to cutting up the car.
