Results 1 to 8 of 8
    duglas is offline SRT8 Owner
    Jun 2004
    Chesapeake VA
    Replacing the rear end
    Has anyone made any progress on this????
    If the 250HP rear is 3.23, does anyone know if it is posi?? Or at least limited slip..???
    Does anyone know if there is a gear for the speedmeter or if it is computer controled??
    If the 3.23 is the same size and I can get the speed reading right.. I am willing to buy one to try it and see.. Just would like some more info..
    I went FROM 3.23 to 3.73 in my GS400 and got 1/2 second faster to 60. I used a stock Supra TT Rear,maybe one FROM like s s600 MB would fit......
    2006 Magnum SRT8 Options 1 and 3, Sunroof
    Zoomers, K & N CAI, Jet Chip Stage 2 180 Therostat
    Rk Sport Hood, Mopar Remote Start
    RX 75 PRO Radar Detector
    $.25 Fan Mod (Cost me $6)
    392.5HP 394 FT LBS!!!!!
    13.02 1/4 Mile
    1972 Dodge Challenger 6.1L SRT8 6 Speed
    1995 Nissan 240SX SE Stock
    2005 Toyota Sequoia
    1997 Jeep Wrangler
    2005 Dodge Magnum R/T Blue 321.9HP 372 Ft LBS-SOLD
    1965 Corvette Convertible. 327/365HP red/black SOLD
    bigdaddyoc is offline Do work!
    May 2004
    Corona, California
    I am VERY interested in doing this as well. Both of my last 2 cars had 3.42's and made driving alot more fun. Although the power of this car can make up for some of the gear it could use a little more help.
    '11 Charger RT Plus- Bright White
    22" II Crave wheels (USW's soon) LMI Hammer intake, 85mm BBK, Mopar Strut braces F&R, Corsa Sport exhaust. Trufiber CF hood, KW coilovers, BT underhood treatment, Custom engine bay covers/paint. Coming soon... ICE and a few more suprises from vendor R&D....
    RETIRED -'05 Black Magnum RT
    MySRT's Avatar
    MySRT is offline LX Guru
    May 2004
    Charlotte, NC
    My quess would be the spedo is controlled by the computer. It will require a software change to account for the rpm ranges. This is what has to be done with GM rear wheel drive cars.
    Don
    Live Well, Love Much, Laugh Often
    www.caringbridge.org/visit/donpusso
    E55 KEV's Avatar
    E55 KEV is offline LX Padiwan
    Mar 2004
    Washington D.C.
    The rear end final gear ratio in both the 3.5 & 2.7 liter V6 is listed as 3.90 per Dodge.com Magnums Specifications. That is better!
    • My Website - www.E55AMG.com
    • 2002 Mercedes-Benz E55 AMG
    • 2005 Dodge Magnum RT Hemi
    • 2005 Chrysler 300C Hemi
    Jun 2004
    Chesapeake VA
    rear change
    Someone needs to figure this out.. if the 250HP has a 3.90 with a 4 speed trans, then the RT with the 5 speed should scream with it and be OK on the highway..
    MY Gs400 speed was controlled by the Navagition so I did not have to do anything after I changed the rear, the speed was never off, but I am sure it is a software thing in the Magnum.. BUT, should not be that hard to figure out...
    13.02 1/4 Mile
    2005 Toyota Sequoia
    1997 Jeep Wrangler
    convbcuda's Avatar
    convbcuda is offline List Lurker
    Jun 2004
    Northern Virginny
    The 5 speed's gear ratios are lower, so the final drive ratio shouldn't be too high.
    http://scoop.daimlerchrysler.com/pdf...ifications.pdf
    SPECIFICATIONS- 04
    TRANSMISSION: AUTOMATIC, 4-SPEED OVERDRIVE
    Availability...................................... .................................Included with 2.7L and
    RWD 3.5L engines
    Description....................................... ...............................Three planetary gear sets, one
    overrunning clutch, full electronic
    control, electronically controlled torque
    converter clutch
    Gear Ratios
    1st............................................... ...............................2.84
    2nd............................................... ..............................1.57
    3rd............................................... ..............................1.00
    4th............................................... .............................. 0.69
    Reverse........................................... ..........................2.21
    Final Drive Ratio............................................. ................. 2.7L – 3.90, 3.5L – 3.64
    Overall Top Gear Ratio............................................. ...2.7L – 2.70, 3.5L – 2.51
    TRANSMISSION: AUTOMATIC, 5-SPEED AUTOMATIC
    Availability...................................... .................................Std. RT, included with AWD
    Description....................................... ...............................Adaptive electronic control or
    AutoStick® driver-interactive
    manual control and electronically
    modulated torque converter clutch
    Gear Ratios
    1st............................................... ...............................3.59
    2nd............................................... ..............................2.19
    3rd............................................... ..............................1.41
    4th............................................... ..............................1.00
    5th............................................... ...............................0.83
    Reverse........................................... ..........................3.17
    Final Drive Ratio............................................. ..................5.7L RWD – 2.82, AWD All – 3.07
    Overall Top Gear.............................................. ...........5.7L RWD – 2.34, AWD All – 2.55
    2.82 X 3.59 = 10.12 overall for 1st gear for the 5.7.
    3.50 X 2.84 = 9.94 overall for first gear for the V6.
    E55 KEV's Avatar
    Mar 2004
    Washington D.C.
    There is an error on the Dodge Magnum spec sheet page listing both V6 with 3.90 final drives. The Chrysler 300 Spec site has it correct Thanks.
    dvdedmen1RT is offline LX Newbie
    Jun 2004
    Anywhere in the 10s is the magic number for drag racing lanches. But it is nice to have some more gear to smoke to tire easy with just the throttle. Been told my many who have hemi that the start to break in good a around 5000 miles.
    Have you seen the rear? It seams like you have to remove the entire rear pumpkin to change gears. Back suspension cradle is bolted to rear cover. Only about 3 inches between cover and supension frame. Don't get me wrong, I would be one the first in line to swap gears, but definetly going to be more expensive to put gears it. :D
