Results 1 to 15 of 15
    Iceberg62's Avatar
    Iceberg62 is online now LX Newbie
    DFW
    Relocating/Bypassing ESP switch
    Hey guys, I've searched and can't find a definitive answer so here's my situation.
    First, I have an '06 MSRT.
    I'm going to modify my dash bezel and I'd like to relocate the ESP/Hazard/Wiper switches on the dash. I'd actually like to bypass the factory switch and use one of my choice that isn't in the OEM panel. I don't care about the wiper button since I'm getting rid of the rear wiper. The Hazard switch is easy to figure out. I don't want to move the whole panel that has the wiper switch etc in it so I was wondering if anyone knows of a way to bypass my OEM switch. Since the ESP switch is a multifunction switch with the single press and the long press I can't figure out how to duplicate the action with an aftermarket switch. I don't care about the partial off part. I just need to be able to turn ESP off when I want it off without having to ever access the OEM switch.
    I really appreciate the help
    scotto's Avatar
    scotto is offline LX Guru
    Sep 2009
    Windsor, Ont
    Can't it be done with the wire from under the drivers seat. I can't remember which wire it is, but there is a write-up about disabling esp, it also shuts off your abs brake system as well.
    check6x is offline LX Guru
    Nov 2007
    Valley Center, Ca.
    The $5 no esp mod could be what you want. You no longer need the OEM switch.
    Iceberg62's Avatar
    DFW
    Do you guys know for sure if it works the same on SRT models?
    Nov 2007
    Valley Center, Ca.
    I know for damn sure it works on my SRT8.
    moaugust88's Avatar
    moaugust88 is offline I'm up all night to get lucky!
    Nov 2009
    Chicago
    You could use a 300 Hazard ESP switch it's smaller so you can relocate where you'd need it.
    2006 SRT 300C R2C
    CAI and a ton of mods...
    Quote Originally Posted by fatchance
    You take a four-door sedan and make it a rocket ship.
    Iceberg62's Avatar
    DFW
    Quote Originally Posted by moaugust88 View Post
    That's a good idea. I wonder if the plug is the same...
    Iceberg62's Avatar
    DFW
    Quote Originally Posted by check6x View Post
    Which way did you do the mod?
    Nov 2007
    Valley Center, Ca.
    Only one way that I know of and that is to interrupt a particular wire to the silver box in the console.
    scotto's Avatar
    Sep 2009
    Windsor, Ont
    As far as the smaller switch from the Charger and 300, yes the plug is the same. I have the Charger switch in my 06 Mag since I got rid of my rear wiper as well.
    Iceberg62's Avatar
    DFW
    Quote Originally Posted by scotto View Post
    do you have a picture of how yours turned out?
    94cruiser's Avatar
    94cruiser is online now LX Guru
    Apr 2010
    Chicago
    The Charger is missing the wiper switches however the bezel is still the same width.
    The 300 assembly is much smaller. Wonder if that one has the same plug on it.
    Good idea. I think with that you'll get best of both worlds.
    Splice in wires and extend the switch to where you want it and still have it clean looking.
    moaugust88's Avatar
    Nov 2009
    Chicago
    Plugs are the same AFAIK just missing pins on the switch because of the lack of pins. Ask people that have done 300 dash conversions, only a handful have done it.
    scotto's Avatar
    Sep 2009
    Windsor, Ont
    Then I guess that I have the 300 button, not the Charger. My button is only 3 wide, the hazard, esp and a blank. And yes it is plug and play as well, I extended my wires from the top of the bezel to just above the ashtray where the cd pocket was filled in, and the hazard and esp both work the same with the 300 button. But like it was said, the 300 button will not fit in the stock location for the Magnum as its smaller across.
    Illinois Chaos's Avatar
    Illinois Chaos is offline that's gonna wake the neighbors
    Apr 2010
    on the highway to hell
    Just jump the blue wire w/purple stripe under the console on pass side bundle of wires. full off 100%
    Pick a lane...same destination
    2011 IMSM Pro Outlaw Street Heat Division Rookie of the Year
    2012 Midwest Index Shootout Pro Outlaw Street Heat Division Champion
    HEADS-UP DRAG RACING
    10.645 @ 125.18 Tuned by Tim Barth @ MPH Racing
