While I was at the dealers anyway I decided to CHECK on a 300C with the rain sensing wipers. The cool news is that the selector switch is no different than the regular one. You must have the EVIS installed to get the rain sensing wipers to work. There is a selection that allows you to turn it on or off. Once it is on all you have to do is move your selector to the slow position and the rain sensor will adjust accordingly. I believe all you need to do is install the rain sensor to the front windshield and figure out where it needs to be wired into. If anyone has access to that information please post it here. I think it would be cool to have this added to my Magnum once I get it.
If the switch doesn't have to be replaced then its just a matter of installing the rain sensor which is just under hte rearview mirror. That will depend on if they ran the wiring for it which is a big if. Swapping out the wiper controler is a BIG job requiring removing the steering wheel assembly including the air bag.
