I want to paint my manifold black, but I don't like the texture it has stock. Any advice on sanding it down? What paint to use?
Thor From Sweden - MSRT '06Procharger P1SC-1 // Ford 80lbLegmakers // AAC // Billet Tech // 3G CustomZ // Diablo
Innovate LC1 // Nitrous Outlet Addict
Which ever that gets the best result. I can paint myself, and I have a company who powder coated all my 3G customz parts for 80 bucks so they can do the manifold.
First remove the coating thats on the manifold with a aircraft grade stripper then have fun sanding if your gonna powdercoat then you should only need to go down to a 80 grit as the powder will melt and fill the small crevices. good luck
I always just use spray paint with some high heat primer.....works well for me, never cracks or looks bad! I spray painted my 20" clads and they held up pretty well! Look pretty damn good for 20.00 and a couple hours of time. I DD the car and it's been through rain, heat, cold and same paint has been on the wheels for 2 years now.
first time out 11.28 @ 123.94MPH 1.89 60ft +3500DA R.I.P Kenne Bell
The op wants it smooth
Any advice on which grits to use?
get yourself a dremel or a cheap one from harbor freight and and an orbital sander...makes quick work of large areas then use the dremel for the hard to reach spots and grooves...
start with 20-36 grit and work your way up
I'm starting to think our cars might look pretty damn similar by the end of the year![]()
2006 Magnum SRT8
D1 Procharged
https://www.youtube.com/watch?v=DFEDiEw5qR0
Why is that?
Black MSRT with Black Wheels, Procharger D1SC, 3g engine dress up, painted/powdercoated intake manifold, etc. It will all hopefully be done by the end of the year.
Ah, yea. It will look pretty slick when it's done. Let's compare pictures later.
I got the aac style halos, challenger wheels and nitrous - what do you have![]()
Mine looks basically stock with powdercoated wheels and tinted tails. Under the hood is just a frankentake with SLP LM2's.
I thik the Wrinkle Black will look good under the hood. Check out Legmakers, he originally had his manifold painted Black then went to the Wrinkle Black. I think the Wrinkle Black looks better. That's something that I'm looking at doing later this year.
