the "easy out" function for my seats doesn't work. i can push the buttons and the saved positions work, but they dont move all the way back when i take the key out anymore. is there a reset procedure for it.
2007 300c srt-d. 5.7 180 t-stat, underdrive pulley, long tube headers, 3k stall, sidewinder cam, egr block off plate, sts kit currently at 5 psi
There is a setting in the evic that will let you turn them off and on
Yes turn the car on,dont sit inside it,move the seat back all the way,than forward all the way,than back again..remove the key and close door.than open the door,sit inside the car start the car and the seat should go to its saved postion,if not press the memory buttom number and once its in the right postion turn the car off and the seat and steerimg wheel should both, move
Sent from my DROID4 using Tapatalk
*New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed
How do I change it from there
That did the trick, thanks guys
