Results 1 to 4 of 4
    TXboi is offline LX Padiwan
    Jan 2007
    Installing LED light strips in trunk, how do I wire them?
    Looking to install a couple of super white LED strips in my trunk. I have an idea on how I'm gonna mount them but need some advice on how to wire them so they come on as soon as I open my trunk. Do I route the power wire to the trunk light assembly? And if I do that how would I go about doing that so it's a clean install? Any other wiring options I can go where they only light up when the trunk is open? I'm not running no switch so that's not an option. Thanks
    2006 Charger R/T
    MODS: JBA System..K&N CAI..ESP delete..93 Flashpaq..20" Black Vipers..15% tint..tinted tails..Blinker mod..Decal/Door Molding Delete..Hood decal blackout..Silverstars..Jenson 9021 touchhscreen..12" JL Sub.."Superwhite" dome lights..quarter panel stripe kit..trunk blkout..daytona grille,chin spoiler,spoiler
    Dreadl0ck's Avatar
    Dreadl0ck is offline Hemi Powered
    Apr 2010
    I'm a Viking from Sweden
    I'd say tap the stock switch that runs the trunk lights
    Thor From Sweden - MSRT '06
    Procharger P1SC-1 // Ford 80lb
    Legmakers // AAC // Billet Tech // 3G CustomZ // Diablo
    Innovate LC1 // Nitrous Outlet Addict
    SuperFrawgie1361's Avatar
    SuperFrawgie1361 is online now formally 2intenz
    Nov 2008
    Panama City, Florida
    run a power wire from battery/ fuse box a toggle switch then to your lights, that way you can turn them on when you want to.....
    Hemi Registry #1348 SuperFrawgie 1361
    geewez is offline LX Newbie
    Mar 2009
    San Bruno, CA
    I did exactly that and it was an easy add on. Simply splice the two wires of the LED strip to the two wires going to the factory trunk light. You can check with a volt meter as to which wire is hot and which wire is ground. Quick 15 minute job.
