Results 1 to 7 of 7
Thread: hot gas!
    DawsonMagnum's Avatar
    DawsonMagnum is offline Wielder of Mjolnir!
    Jun 2004
    Duluth, GA
    hot gas!
    No, this is *not* about flatulence.
    What this is about is race gas. I am in reasonable driving distance of a service station that sells 100 Octane race gas and I am seriously thinking about getting some in my tank at some point to see what that does for performance. I wonder, though, is it safe to run it in these hemi's? Has anyone here done it yet? Would it void my warranty?
    I could run it in my Audi S4 all day and it wasn't a problem, but I figure better to be safe than sorry.
    Alis volat propiis.
    Glenn Harper - 2006 Brilliant Black Magnum SRT8
    Mods: FRI Fatman Cam, FRI Full Street Heads, Coated Intake Manifold, Coated Kooks LT Headers & hiflo Cats, B&G Stage II, Corsa Catback, 170 TStat. Various BT interior items & Custom Console Cover by Jina!
    snickle's Avatar
    snickle is offline LX Old Timer
    May 2004
    You won't have any problems, but you won;t see any gains either. HIgher octane just means a higher ignition point, so your engine can run at a higher compression. Our Hemi's won;t so you are fine.
    2005 Dodge Magnum RT - Midnight Blue Pearl
    Volant CAI, 190 Thermo, Mr. Grille Vertical Grille,
    SXT Headlights, MDS Monitor, Bel 975R,
    Infinity 3002cf (dash),Blaupunkt 605 woofer (door), Infinity 6002si (Rear),Infinity Basslink, SC Tuner, GSM Fan/Traction Mod, 22elite Heal Guard, Factory One Tail lights
    henry's Avatar
    henry is offline Cunning Stunt
    Jul 2004
    43 39' N; 79 23' W
    Just make sure it is lead free.
    There's lots of racing gasoline out there that has lead in it.
    You won't see any performance gains, though, so it's just academic...
    billapex's Avatar
    billapex is offline There was one?
    Phoenix, AZ
    The general rule is that you should run the lowest octane possible without pinging. The lower the octane, the easier it is for the ignition system to light off the mixture, and it burns much quicker. The Hemi is designed to run on mid-grade (89 octane), and unless you've done something to increase the power significantly (i.e. blower, turbo, or nitrous), you don't need anything over mid-grade. With, say, 100 octane, you'll notice absolutely no difference in power.
    However, because your wallet will be significantly lighter, the car may be faster as a result. :lol:
    billapex
    '05 Magnum RT (Inferno Red)
    Magnaflows, resonators removed, K&N, modified airbox
    14.68 @ 95.56mph
    '89 Mustang coupe opentrack race car, 475hp, 2,800lb., 335s all around
    Jun 2004
    Duluth, GA
    Thats a shame. I loved the extra power I got FROM my S4 w/ the race gas. So much for quick'n'easy power boost.
    C4me is offline LX Padiwan
    May 2004
    Ohio
    Quote Originally Posted by billapex
    Right-o BUT, octane is ONLY for anti-knock. Nothing to do with power or quick boost. Nothing at all. IF you have a high compression engine, higher octane will stop the dreaded "knock".
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    You will see VERY little gain... save your money for a couple of cans of that new high performance tire air
    And the dead shall walk
