Results 1 to 15 of 20
    bskylerj's Avatar
    bskylerj is offline SICK 392
    Nov 2006
    Spokane, WA
    HID install help
    Alright guys. I need some help. I got these to install into my fog lights. It seems like something is missing to me. Any help would be great. Here is the type of kit , instructions, and pictures. There is no wires to lead to the battery for the power?
    Ballast and bulb.
    Ballest wires
    HID bulb and wires
    Instructions
    2011 SRT8 392 Challenger. Black, Loaded, Stripe delete. 22x9 front and 22x10.5 rear
    mofoninja's Avatar
    mofoninja is offline ROLLOWT!
    Mar 2006
    Bothell
    I believe this is how it works...
    *EDIT* Un-durrr'ing my post thanks to Numbasyx's post.
    Hey bud!
    Like Numbasyx states below...
    connect the male end that would usually connect to your current fog light bulb to the circled female.
    Don't sweat the flicker issue when running these to fog lights.
    will drift for energon | witness rodimus in action!
    bskylerj's Avatar
    Nov 2006
    Spokane, WA
    This was everything in the kit....
    I need you to send me some info for the convoy. Check out the NW posts
    gameover's Avatar
    gameover is offline voiding warranties
    May 2006
    New Orleans
    That female plug circled in this picture would mate with the existing male connector that is plugged to your foglight. Also I do not see any resistors/relay/idiodes on your harness so they might start flickering. Do you know anyone with this kit on a LX vehicles?
    05 RT . Jett Black . SRT Fascias . UAS . AFEII . Zoomers . Forgiatos . Wilwoods ...
    Braddah Jay is offline Doin' 120+ on the 14 frwy
    Palmdale, CA
    I believe you can get the anti flicker adapter from "Stealth Auto"
    mofoninja's Avatar
    Mar 2006
    Bothell
    You don't need to worry about the flicker issue when running these as fogs.
    bskylerj's Avatar
    Nov 2006
    Spokane, WA
    I took the one in red and hooked it to my drivers side fog light end that was hooked to the original bulb. I then took the 2 plugs circled in yellow and plugged them into each other. Does this sound right? When I turned it on it did not work.
    gameover's Avatar
    May 2006
    New Orleans
    Quote Originally Posted by mofoninja View Post
    Thanks for the heads up. I wasn't aware about the foglights not flickering with a basic HID kit. Learn something new everyday.
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    Seems Like Your Missing A Connecter On Those Blue And Black Ones??( A Female One Like The 1 On The Ballast)...... My Aac Hids I Had To Run Wire To Neg. And Pos. But Mu Fog Kit Was Plug And Play??? Dont LOOK Right.. YOU GET THOSE NEW???
    gameover's Avatar
    May 2006
    New Orleans
    Hmm it should work. Did you check the fuse? Have you tried switching to the other ballast/ bulbs just to see if there are any defects?
    That black and blue looks like a hardwire. My kit was a plug and play and didn't require to tap the battery terminal like that instruction says. But then again I don't have HID on my fogs, just my headlight.
    bskylerj's Avatar
    Nov 2006
    Spokane, WA
    On my headlights I was the same 36. But these are supposed to be a plug and play...
    CentralTexHemi's Avatar
    CentralTexHemi is offline LX Padiwan
    Jun 2007
    Not going to contradict you on this but every HID kit I have installed you HAD to run a positive feed to the battery and a ground to a ground source, this allows power to be sent to the ballast, looks like your missing a part to me. The relay may not be needed but I always use them, here are some pics of my install using the Mcculloch HID kit similar to this one
    2007 SRT8 Jeep Grand Cherokee
    12.23 1/4 JB CMR Tune and AFE Stage 2 intake only mods...
    7.81 1/8 Same mods.
    Jun 2007
    7.81 1/8 Same mods.
    Jun 2007
    7.81 1/8 Same mods.
    Jun 2007
    These 2 pins have to be inserted into the clip the correct way and make sure they snap in the right direction, honestly if your not comfortable with installing this kit there is a much better kit that you dont have to put so much together and is alot easier to install at kbcarstuff.com
    7.81 1/8 Same mods.
