Results 1 to 12 of 12
    Ikarus's Avatar
    Ikarus is offline Supporter/Club Member
    Nov 2004
    Merritt Island, FL
    Question HELP: Removing door panels
    I am still working on getting my window sills installed.
    I have removed all the push pins holding the trim and all the screws. I am now trying to remove the panels themselves. I am currently working on the rear passenger door. The top of the door, where the panel meets the glass, I follow until I reach a clip in the back. I have pulled at this point, per the instructions, but this clip is not coming loose? Any trick to it or do you literally just pull until it opens?
    Any help is appreciated.
    Ikarus
    2005 MAGNUM RT AWD
    2003 MINI COOPER
    Feb 2005
    GA
    SmoovC's Avatar
    SmoovC is offline M45 Maniac
    Apr 2006
    Graham, Kracka'!
    Put your left foot on the bottom rear of the door jamb & pull straight towards you!!
    2006 Infiniti M45: Diamond Graphite Metallic, Premium Package Option Group w/ Mobile Entertainment System, Tein H-Techs & KYB Lowered, Magnaflow Exhaust
    2000 Dodge Dakota C/C R/T: Flame Red 5.9L, 1 of 800 Produced, Belltech Lowered, 20" R/T Replica Wheels, Flowmaster Exhaust
    More pics at:
    Visit us at:
    BUTWEET's Avatar
    BUTWEET is offline GOOD MEAT TAKES A LONG TIME!
    Bothell, WA
    Look down from the top to locate the clips. Grab the door top at the site of the clip and give it a "quick" yank. It will come, my son.
    MY MEAT WILL MELT IN YOUR MOUTH....NOT IN YOUR HANDS! ENJOY THE Q.
    Ikarus's Avatar
    Nov 2004
    Merritt Island, FL
    Thanks for the advice. Tonight is the first night I get a chance to try this again so if I damage something I will let you know. :-)
    Ikarus
    2005 MAGNUM RT AWD
    2003 MINI COOPER
    Bo's Avatar
    Bo
    Bo is offline Because Unicorn
    Mar 2004
    Austin, TX
    Quote Originally Posted by Ikarus
    When the clip does release from the top of the door..... you will certianly think you have broken something..... never fear.... the clips just work as they were designed! If the clip comes loose from the door panel, make sure to put it back on the panel before you reinstall it.
    --Bo
    Ikarus's Avatar
    Nov 2004
    Merritt Island, FL
    Do you actually lift the panel over the door lock first and then pull or pull it and then lift it over the lock? I will mess with it later anyway, but I might as well ask now.
    Ikarus
    2005 MAGNUM RT AWD
    2003 MINI COOPER
    quarky42's Avatar
    quarky42 is offline LX Guru
    Jan 2006
    Las Cruces, New Mexico
    I don't know if this is the same style push pin that is on the rear hatch trim:
    On the rear hatch trim I used a butterknife at the base of the pin and twisted the knife while pulling on the panel. It took a lot less force to remove the panels with the help of a lever/tool twisting/prying the pins than without.
    Did the radiator cap mod: SRT8 is here....
    The Hemi says, "VROOOM!" Hemi Registry #00420
    BUTWEET's Avatar
    Bothell, WA
    Pull panel first, with quick and short pulls at the site of each clip. Then you can lift up a little bit and work the panel over the door lock. Don't forget to unplug the plug at the window switch before you whirl the panel away from the door. Like Bo said.....the top white clips that are attached to the door tops, can become dis-attached, so make sure they're in place before re-installing. For re-installing: When the clip is lined up with the hole (and make sure it is) firmly push and you'll hear the barbs go in the hole. I give a light rap over each clip just to be sure. Continue down the line. (MAKE SURE YOU PLUG IN THE WINDOW SWITCH BEFORE RE-INSTALLING THE PANEL) It really sucks when you have to repeat the whole process. Have fun!!!
    bluesteel's Avatar
    bluesteel is offline Blue Steel
    Feb 2006
    Manassas, VA
    I am about to attempt to install lower window sills for the first time. Kinda nervous but have confidence I can do it without damaging the door.
    Which window sill are you installing? Upper or lower? Both?
    '05 Magnum RT, Midnight Blue Pearl - Mods: 20% tint, Dub chrome door handles, debadged rear door (except Rams head), silver billet knob covers (MRK Group), Dub chrome lower window sills, stock navi upgrade, silver bulbs (front and rear), blinker mod, and fuel door mod.
    Ikarus's Avatar
    Nov 2004
    Merritt Island, FL
    Quote Originally Posted by bluesteel
    I actually only want to do the lower. The upper is kewl, but I don't want to have to deal with thep pillars. For me, the lower looked like it would complement the side moulding without drawing too much attention to itself.
    Ikarus
    2005 MAGNUM RT AWD
    2003 MINI COOPER
    Ikarus's Avatar
    Nov 2004
    Merritt Island, FL
    Quote Originally Posted by Bo
    Even knowing this I can only say that you cannot possibly be prepared for this sound. I said many special words that need not be repeated here as soon as it came loose.
    My only advice for this clip is not to bother trying to use anything to pry it. Pulling the door firmly really was easier even with the terror.
    Ikarus
    2005 MAGNUM RT AWD
    2003 MINI COOPER
