Results 1 to 11 of 11
    deleted
    tommyzdesign's Avatar
    tommyzdesign is offline just an lxer
    Jun 2005
    anywhere theres a Lxer in need.....
    On the phantom you push it back in and hold it for it to turn off.
    z
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    I believe the SRT-10 truck has a regular ignition switch without the start position. You turn it on and then press the big red button on the dash
    fnkychkn's Avatar
    greasy cardboard box
    to start, turn ignition key to run position, then press start button.
    to shut down, turn ignition key to off position.
    Darthvader is offline 'waste of skin'
    Nov 2005
    Ya it's like an extra step. My wifes car has no key and a button for on and off. She hates it too.You still need to find the fob to lock unlock and remote start.
    NC-SXT's Avatar
    NC Coast
    Quote Originally Posted by 65standard View Post
    i thought you would just keep a fob in your pocket and only have a push start button and if you didn't have the fob on you, the car wouldn't start.
    i would like to just get in my car and push the start button and go. push it again to turn it off. is that feasible?
    Thats the way most of the Toyota and Nissans do it as long as you have a key fob within a specified area.
    WWW.DodgeMagnumGrille.com
    betcustomz is offline LX Newbie
    Nov 2007
    Thats what im trying to do.
    markus's Avatar
    markus is offline whats up with it vanilla face
    Northern VA
    Quote Originally Posted by Darthvader View Post
    what a HUGE inconvenience
    markus's Avatar
    Northern VA
    just thought of this:
    what if you had a hidden kill switch inside the car so that you couldnt start it unless the switch was in the on position. remove the actual part that the key goes into and wire the push to start directly into it.
    Nov 2005
    Quote Originally Posted by markus View Post
    For a dude it's not. Unless you are like Buttweet and carry a large purse loaded with crap.
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
