will the following part numbers only fit the v6 magnum or will they fit other v6 models as well? thanks in advance.
2873.001
2873.002
- Avic-D3
- 300C Woodgrain Steering Wheel
- 300C Woodgrain Shifter
- AudioBahn 3-Way Rear 6 x 9's
- Demolded
- Slotted and Drilled Rotors
- Black Lugs
- Air Silencer Delete
- CHRYSLER Emblems
Best bet would be to call Eibach.
What are you wanting to put them on? I ask because those are the springs I have to put on my 300 3.5L v6.
They are listed for the 300C but when I called them they told me that the 300's v6 & v8 use the same front springs. The backs are different spring rates the v8 is higher and they are 7mm longer. So I am planning on using bottom isolators in place of the tops in the rear. So we shall see how it turns out..
I didn't tell them thats what I was going to do, I am sure they would have advised against it
so you have both pairs on your chrysler 300? thats what im trying to do but the website says the magnum is the only v6 it fits. didnt make much sense to me. i thought the added weight could be the only reason.
I have not installed them yet...
oh ok...thanks for the info though. there is a guy selling the set locally for $100 so i think im gonna snatch them up.
