Results 1 to 15 of 16
    snickle's Avatar
    snickle is offline LX Old Timer
    May 2004
    Daytime Running Lights
    I saw a post about park sensor FROM MGD and followed it. He mentioned he installed an aftermarket DRL on his 300. I followed the link. It looks good. Here is the link:
    http://www.webelectricproducts.com/drl/drldetails.htm
    I will ORDER it soon and do a how-to when I install. I will probably install an over ride switch as well.
    Thanks MGD
    BrilliantBlackHemi's Avatar
    Feb 2004
    Been here 7 years!
    Maybe I missed this, but why not just install the factory DRL used in the Canadian cars? Is it not a plug in module like on the LH cars?
    R.I.P. Dad aka DynoBob
    snickle's Avatar
    May 2004
    My understanding FROM other posts, but I have not validated, is that the US model will not recognize the module. I few people have loked INTO it.
    I kind of like using the turn signal as DRL, instead of of the headlights. Some of the headlight based DRLs, including my current car, can be a little bright.
    2005 Dodge Magnum RT - Midnight Blue Pearl
    Volant CAI, 190 Thermo, Mr. Grille Vertical Grille,
    SXT Headlights, MDS Monitor, Bel 975R,
    Infinity 3002cf (dash),Blaupunkt 605 woofer (door), Infinity 6002si (Rear),Infinity Basslink, SC Tuner, GSM Fan/Traction Mod, 22elite Heal Guard, Factory One Tail lights
    Feb 2004
    Been here 7 years!
    Can anyone else confirm this too?
    C-Man's Avatar
    C-Man is offline 2005 300C Man
    Jun 2004
    Palm Harbor FL
    I know of someone who has turned their headlights INTO DRLs using this product.
    http://www.securityworld.com/lightin...merunning.html
    Just be aware that the headlights are in parallel and not serial so you will need to run a wire over to the other headlight. This link tells how he did it..
    IS300M is offline LX Padiwan
    Feb 2004
    Mass
    In Intrepids, all you have to do is plug in the DRL module and it works!
    Feb 2004
    Been here 7 years!
    That's why I'm finding it hard to believe we can't do that on the LX.
    snickle's Avatar
    May 2004
    We can do it with an aftermarket unit. As for the Canadian setup, I 'll wait until my car shows up in a week or so and then dig INTO it a little deeper.
    Feb 2004
    Been here 7 years!
    When I get mine, I will inquire about it at the dealer.
    Fred is offline LX Guru
    Coram, NY
    It would be better to do it "legit" ie FROM dealer's service dept programming the car rather than installing a piece of hardware which involves tapping wires under hood... In the end, the wire taps breach the integrity and can cause all sorts of problems...
    If the dealer tells me it's not possible due to lack of programming etc, THEN I will pursue a hardware method of seting it up...
    Mikeyjohn is offline LX Padiwan
    May 2004
    Calgary Alberta Canada
    The DRL's is a turn-on system using the starscan but they won't do it on US cars unless they are rentals. I don't know why this is but you will have to ask DC. The 300M had a module on the Cdn cars but a lot of members of the 300M club bought the module FROM DC and I think they paid about 80 bucks for it. I of course have the DRL's on my C and love them, but then they are mandatory here.
    Coram, NY
    Well the service manager said he will enable them on my newly arriving mag rt
    memory1 is offline LX Newbie
    Jan 2005
    Irvine, CA USA
    While researching this topic I found some technical info
    1: Daylight running lights use the headlights controlled by PWC, pulse width control,
    2: In Canada they use lower beams while in the US fleet(rental) cars use the high beams
    3: You probably need the ambinent light sensor on the dash to work prperly
    4: It might be as simple as a dealer flashing the proper module !
    BobF's 6POINT1's Avatar
    May 2004
    PHXAZ
    In case anyone cares, our buddies at Highhorse Performance also carry this mod
    http://estore.websitepros.com/802805/Detail.bok?no=219
    oldtimer is offline LX Newbie
    Apr 2004
    central Il
    I have the DRL-1 module installed on my RT. I also have the auto/light switch installed.
    I wired the DRL-1 with the overide option. All light functions operate normal.
    L Webb :D
