Results 1 to 6 of 6
Thread: Clear on rims
    Srt_Driver's Avatar
    Srt_Driver is offline LX Guru
    Apr 2010
    Chicago,IL
    Clear on rims
    So I painted my rims black about 2 months ago.they are still holding up nice with no chips or cracks...I didn't clear coat them at the time because it was to humid outside and I did try to clear on rim and it was starting to turn white'ish instead of a glossy black..now the humidy is under 50% and its a nice 60 degrees outside..would clear coating the rim now make it look glossy?I'm using the duplicolor rim paint,and duplicolor clear coat
    Sent from my Droid!
    *New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed
    scotto's Avatar
    scotto is offline LX Guru
    Sep 2009
    Windsor, Ont
    I've found the Duplicolor clear spray sucks. I have wrecked so many parts using it with bubbles and it turning milky right out of the can. And that was in all different temps and humidity levels.
    drag_racer is offline LX Guru
    May 2010
    Dalmeny, Sask.
    Quote Originally Posted by scotto View Post
    I have had it turn milky when first sprayed on but it dries clear
    Performance mods: Predator Tuner, Deleted Resonators, Custom Dual CAI, Toyo Proxes 4 245/45/20 tires
    Visual Mods: Door Molding and Rear badges removed, LED Tails, 20"x8.5" American Racing Phantom Rims, Front upper/lower crosshairs deleted
    Best ET:
    60' - 2.08
    1/8 Mile - 8.99 @ 78.55 MPH
    1/4 Mile - 13.97 @ 99.7MPH
    Srt_Driver's Avatar
    Apr 2010
    Chicago,IL
    I defently don't want it milky..anyone recommend anything good that's works
    Sent from my Droid!
    May 2010
    Dalmeny, Sask.
    Make sure you do NOT mix brands of paint. Since you used dupi-color paint, make sure you stick with dupli-color clear. Mixing brands of paint can cause huge headaches with it not sticking (I sprayed dupli-color over armor-coat primer and the dupli-color just flaked off, even though it was applied the same as all the other things I have painted with all dupli-color with no issues.
    sprinkler1's Avatar
    sprinkler1 is offline LX Padiwan
    May 2009
    I would recomend spray max 2 part clear in a spray can SprayMax 2K Urethane Aerosol Clear Coat
