Results 1 to 6 of 6
    roadpig is offline LX Newbie
    Aug 2005
    attn funky- switch location
    looking for the location of the ignition switch on my 05 magnum r/t
    thats wired into the harness- thought funky might be able to tell me- would
    save me from possibly pulling panels off i didnt have to- thanks!
    roadpig
    fnkychkn's Avatar
    greasy cardboard box
    the ignition switch is mounted to the end of the ignition lock cylinder. to access connector, remove knee blocker. to remove switch, a few more trim panels need to be removed.
    Aug 2005
    thanks funky! appreciate the info! roadpig
    Jaak's Avatar
    May 2005
    I smell a pushbutton starter...
    2006 Magnum SRT8 - 11.85@117
    Aug 2005
    it works! however- when i use the pusbotton to start the car- auto headlights
    will not work- used pins 4 and 5 on ignition switch and used an srt10 pushbutton
    and used pin 2 on the button- with power to pin one on the button- could this
    problem possibly be due to not getting the drop in resistance to the cluster from the ignition switch when using the button instead?- everything else seems to work- and yes i did install a 300c auto headlight switch months ago
    i can live with it this way- just would like to know if theres a fix here or if i could damage something like the cluster or whatever leaving this button wired up- ps-
    if i use the start button and then flick the key to start on the dash the auto headlights will work! funky? thanks roadpig
    Jaak's Avatar
    May 2005
    Looky here...
    Starter button
