Results 1 to 15 of 28
    Duke's Avatar
    Duke is offline Jobless-will work for money-NE1 in Utah?
    Apr 2006
    The North Coast
    Any LEDs work for the interior lighting?
    A while back I (and a bunch of other people) got these LEDs for our interiors and license plates. Since then the 194 LEDs slowly started to flicker and eventually stopped working. They went out after about a month or three after I installed mine, and same for the other guys. The other bulbs worked just fine and still work now.
    What I want to know is if anyone has anything that they have that has worked for a long time. Around a year or more. 194
    Quote Originally Posted by Duke View Post
    We used these bulbs for the front and rear lights
    http://autolumination.com/festoon.htm
    Introducing the
    The Widest, Brightest and Best Festoon Leds Ever Made!
    Outfitted with the latest Super High-Flux Leds
    Designed especially for applications requiring a large uniform field of bright light
    10mm wide x 44mm overall length
    We had to get 4 of these
    Then for the lights over the rear seats we used these
    http://autolumination.com/194.htm
    Introducing the Newest
    The Widest, Brightest and Best 194 Leds Ever Made!
    Outfitted with the latest Super Wide High-Flux low profile Leds
    Designed especially for gauges, & applications requiring a super-wide large uniform field of bright light
    Only 10mm diameter x 26mm overall
    We used 3 of these, 2 for in the car and one for the license plate light
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    you have to buy the more expensive ones with heat sinks etc the more it cost the longer it will last!!!
    Duke's Avatar
    Apr 2006
    The North Coast
    Quote Originally Posted by 36 chambers View Post
    Do you have them? and for how long?
    yes i got some used and bought some new.. i have 36 led map lights. 2 .....one in each side smt tower rear 1 for each side in rear ...these have five leds... 4 on sides 1 on top used the same on interior lights and licsense plate light
    and i got the 30 tower smt for my brake lights.. none have burnt on on me yet!!
    Duke's Avatar
    Apr 2006
    The North Coast
    How long have you had them all for?
    i have had my new ones for 2 months.. used ones are about 6 months old!!
    Duke's Avatar
    Apr 2006
    The North Coast
    Some of mine lasted a good 3 months, then they went out. Before I just on the new ones with the heat protection I'm going to wait and see if anyone else has had any issues.
    Duke's Avatar
    Apr 2006
    The North Coast
    PHANTZM's Avatar
    PHANTZM is offline Formerly known as Suipsycho
    Arizona
    I replaced all my interior lights (map , rear doors , hatch) with the blue LED's from autolumination.com about a 8 mos to a year ago. The one over my passenger rear door did go out after a while , but the others have been fine. I turn them off with the dimmer switch most of the time before starting the vehicle though. I don't remember the exact ones I got , but they were under $60 for the whole set.
    charginscott's Avatar
    charginscott is offline LIVING A DREAM
    Alvin, Texas
    I have the ones from Autolumination - have them for about 9 to 12 months with no issues. Here are the ones I have in the rear lights
    I have the 44mm festoons in the front maps
    "DETONATOR"
    Sidewinder numbers
    1/8 8.45@82.90
    1/4 13.14@107
    Certified AAC Houston Installer
    lowriderman3's Avatar
    lowriderman3 is offline Rut Ro!
    Low Down Dirty South!
    You have to get the LED protectors that they sell and wire it into your wiring. Simple to do. I did and have not had one problem since. I was about to give up on them, until I emailed them and asked what the heck is going on since I had been through numerous ones....Scroll down the page once you click the link.
    http://autolumination.com/equalizers.htm
    Duke's Avatar
    Apr 2006
    The North Coast
    Quote Originally Posted by lowriderman3 View Post
    So you snip the hot wire (+)? and then use the LED snap the LED protectors to finish the connection? I haven't been in there for a while, can you just pull some slack wire out to get to them?
    ^^Exactly...It really is not that hard to do, and I have not had one single problem since then.
    ZMagnum's Avatar
    Tucson, AZ
    I just turn mine off before starting and they are still good. It's been over a year. I'm getting ready to install all my old Magnum's LEDs into the new Magnum. The only bulb that didn't last was the 194 I put in for the license plate light. I think I burned it out at the track when I started it with the parking lights on (and therefore the license plate light on). If I hadn't done that I think it would have been fine. This is my theory anyway.
    Duke's Avatar
    Apr 2006
    The North Coast
    Did you have slack on the wire to pull it from the housing?
    Quote Originally Posted by ZMagnum View Post
    I don't know much about wiring, but from what I read on the LED protectors starting the car with the lights on kills the LEDs...I haven't had any problem with anything but the 194s. I think I'll try the protectors and hope to goodness that I don't have to rewire some of the car.
