are there some adapters i can buy to make them fit a v6? also what years have tpms that work on the same frequency?
- Avic-D3
- 300C Woodgrain Steering Wheel
- 300C Woodgrain Shifter
- AudioBahn 3-Way Rear 6 x 9's
- Demolded
- Slotted and Drilled Rotors
- Black Lugs
- Air Silencer Delete
- CHRYSLER Emblems
does the v6 have tpms as an option on the car? as long as you get tpms that are the same year as your car, you should be good.
2008 Charger SRT8 dubbed "The Sequel." Black on black is back.
Tell your friends.
yeah it does. as far as the years go i think i remember reading somewhere on here that 05-07 use 315mhz and 08-10 use 433mhz. i was just wondering if anyone can verify this. but still...what about the wheels? can i just get some adapters?
3mm spacers for the fronts should do the trick. BT has them and they're often found in gurgle sale section here.
2005 MRT, CV, K&N CAI, 20" Black Powder Coat CSRT OEM Wheels
I put 300 srt wheels on my v6 ,used 3 mm spacers on the fronts only![]()
