Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
Like Tree3Likes
Thread: 07 PCM Swap on 05 - Having codes P0443 and P0622
  1. #31
    done's Avatar
    done is offline Hanging out for 8 years
    Old Hickory, TN
    I went through this process of switching to the newer style coilpacks a couple of years ago. My PCM fried and I had it towed to the dealer. They fried the first PCM they installed. They finally replaced one of the coilpacks and everything has been OK since then.
  2. #32
    rickdogg's Avatar
    rickdogg is offline Stroked n blown E85 5.7
    Sep 2010
    OC, CA
    What codes were you getting initially?
    -Thank you to my sponsors: Baid Polish, Billet Technology, DTM Autobody, JP USA/ Vizage, LuX Technologies, Shine Auto Project
    -My E85 5.7 FI build: http://www.lxforums.com/board/f61/mi...ge-etc-293543/
  3. #33
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by rickdogg View Post
    The cylinder specific misfire codes.
  4. #34
    rickdogg's Avatar
    Sep 2010
    OC, CA
    That was going on with 05 PCM along with coils not firing period. . Swapped coil packs over from functioning cylinders and same problem persisted so it was a harness issue to begin with, which makes a lot of sense. Now different codes show up entirely. Now we're here 2 PCM's later. Going on 3rd, which will be an 06 this time.
    This ordeal was a great learning experience and expensive. If it wasn't for Hemi31 and especially AMP, this would have been very costly. Thank you so much again to the Lxf community.
  5. #35
    rickdogg's Avatar
    Sep 2010
    OC, CA
    Received PCM and key module the other day. Apparently, engine harness will be here tomorrow. My 1 year old spilled water all over my laptop, so I'm now using my phone for everything. I tried googling RF filter since Hemi31 told me that 06+ engine harness will have that and will need to be crimped to the filter. Anyone have a part number for what I should be lookin for?
    TIA
  6. #36
    rickdogg's Avatar
    Sep 2010
    OC, CA
    Swapped out engine harness and new PCM. Getting misfire code P0306 Cylinder #6.
    Troubleshooting attempts made:
    -Swapped coil packs 4 & 6 and same issue.
    -Changed out new spark plugs in #6 same issue.
    -Pulled harness on injector #6 and idle stayed the same.
    -pulled harness on injectors 2,4, then 8 individually to compare and all changed idle.
    Thinking that it is probably a bad injector going to cylinder #6. Does anyone have a spare?
    TIA,
    Rick
  7. #37
    rickdogg's Avatar
    Sep 2010
    OC, CA
    Weird thing is upon start up there are no codes thrown until I drive around for a few minutes. If I leave it in idle, it throws no codes.
  8. #38
    rickdogg's Avatar
    Sep 2010
    OC, CA
    Swapped in new camshaft sensor since it was right next to water neck and easily accessible and same problem persists. Saw other thread and have crankshaft sensor as well, but haven't changed that yet since it's near the starter.
  9. #39
    concussion's Avatar
    concussion is offline So that's what mid 11s look like....
    Charlotte, NC
    geeze bud, what a shamble.
    http://www.cardomain.com/ride/3247903
    The Old: Stock 5.7 Bottom End | Lead Foot | 11.861 @ 112.76 1.63 60'
    The New
    : Forged Arrington 6.1 | MMPG Top End | Paramount Drivetrain | 11.67
  10. #40
    rickdogg's Avatar
    Sep 2010
    OC, CA
    Okay so after all of the above tests, we tested for power going to coil pack and injector #6. Initial tests showed that coil pack #6 was not receiving power. My uncle and AMP then recommended to get a continuity test. I felt that I did as much as I could in the parking lot of an apt complex, so I took my car to my mechanic to further troubleshoot.
    Findings:
    -Engine harness is fine.
    -Pulse not being received on both coil pack and injector on #6.
    My mechanic believes that the PCM is not sending pulse. However, I'm confused since Jon tested the PCM prior to sending it out. The grounds were all in place and the engine harness is for 06+ coil packs, so I have no idea on where to go from this point.
    -Could start up tune cause this?
    -Could initial ground issue hinder grounds somewhere else that new engine harness did not replace?
    Any input is much appreciated. I just want my car running before my wife kills me!
  11. #41
    rickdogg's Avatar
    Sep 2010
    OC, CA
    I exchanged pm's with Eric (Hemi31) and he stated that the engine harness was good and came out of his personal vehicle.
    However of course, to be safe I wanted to do my due diligence and source out the issue. I spoke to my mechanic this morning and he stated they did the following:
    -Pulled schematics and looked up what power should be at each injector/coil pack.
    -Tested pulse from PCM to each injector/coil pack using NOID light. ALL cylinder wiring were within spec with exception of #6.
    -Then ran continuity test back to PCM and continuity was fine and engine harness checked out as perfect.
    My mechanic was surprised as well that there aren't any codes being thrown upon start up, idle, and some cruising around. However the code of P0306 Cylinder 6 misfire is of course present once the car is put under load. He believes that there is possibly a bad driver on the PCM. As nothing else would be causing the issue in his opinion.
  12. #42
    Sharma's Avatar
    Sharma is offline Sharma Racing
    Dec 2006
    San Jose, CA 95126
  13. #43
    TheBeej418's Avatar
    TheBeej418 is offline Got a little German in me
    Jan 2008
    Nashville, TN
    I was wondering the same. Searched his threads just this weekend to see if there had been any updates.
    '06 Silver R/T with Road and Track on UAS
