Here is a list of my mods. I keep this list up to date so check back often.
Clear bulbs in front and red rear turn signals.
AirHammer HO
Cabin Air Filter.
Glovebox light.
LED interior lighting.
Airbag warning sticker covers.
Zoomers dual exhaust with X pipe.
Airaid intake.
S&B air filter.
Air Silencer Removed.
Lower radiator flaps removed.
Ram air intake from fog light location.
Fog light bezels with grills installed.
Daytime running lights activated.
Turn signal side marker blinker.
FOG tail lights (black housing).
Tailgate weep hole plugs installed.
Tinted front windows (AZ legal).
Dodge ram's head tire valve caps.
XM Radio with hidden antenna.
OBDII extension cable.
Remote controlled radiator fan.
RKE battery clips soldered.
Rear bumper anti-scratch pad.
Front shock nut covers.
Edashkit carbon fiber exterior accents.
License plate light replaced with LED.
Items I've replaced or had replaced:
Dash (dash bubble).
Shifter chrome trim ring.
Sun visor clips.
Wheels and tires (OEM) from another Magnum SXT.
2005 REF radio replaced by 2006 REF radio with aux-in.
Tailgate lifts.
Lower half of airbox.
Rear window motors/regulators.
Driver's window felt.
Radio/ac bezel.
Passenger side kick panel.
Windshield.
Driver's side windshield moulding.
PCV valve.
Outside rear view mirrors.
Driver's side door gasket.
TSB 18-003-05 PCM flash for voltage fluxuation.
TSB 08-049-06 driver's seat grounding strap.
E14 recall.
Wiper switch & clockspring.
Tail light wing nuts.
Front lower shroud.
Fuel pump gasket.
Idler pulley.
Ya.... that bug bit hard eh?!![]()
How did to enable the DRL's???
Mark2007 Magnum SRT8 aka"Beast"
What kind of LED interior lighting did you do? any pics?
I got everything from http://www.autolumination.com The map lights and tailgate lights are the festoon bulbs (39mm 9 LED). The rear passenger lights and the glovebox light are the 194 bulbs with 5 LEDs inside.
I got white but they have blue.
That's QUITE the MOD list, Mark! And your wife still talks to you. Impressive!![]()
I like the mods: list but your avatar is weird.. I hope thats not you on Halloween.. Ha Ha... What is that?
you crazy guys with your v6s!!!!
LOL
