Need a little help on offset for my wheels. I am about to ORDER a set of 20 x 8.5 for my RWD R/T. Plan on using 255/45/20 all the way around. The car is lowered with Eibach's and I want the tires to stick out further than stock (tucked in too much stock IMO). I was palnning on ordering + 18mm offset. Will that do the trick for my desired look? Thanks
Josh
You wheely are confused! Sorry, I couldn't resist... Sincerly, Elmer Fudd
Not real sure about your configuration. Lowered and wheels out further sounds like problems to me. But then again, I don't understand everything I know about wheel offset.
Attitudes are contagious. Mine might kill you.
The outer edge of the wheel will be about 3/4 inch farther out with that configuration.Originally Posted by jagpegasus
