Thread: Two questions
    Thrusst's Avatar
    Thrusst is offline global warming activist
    Aug 2005
    Two questions
    1. Anybody had an RT with a right pull get fixed properly and had the pull go away? If so, what did they do? I've tried twice, the car still dives into the right lane when you let it go.
    2. Anybody checked their rear left seatbelt? When mine is buckled, the button release is next to the body rather than away from the body. The dealer showed me that it only installs one way but I think the buckle is backwards or the wrong part.
    Thanks!
    2005 Magnum RT - 360 HP
    2005 PT Cruiser GT - 220 HP
    1973 Firebird Formula 400 - 0 HP (soon 400+)
    1992 Learjet 31a - 7000 lbs. of Thrusst
    "THERE'S MORE TO LIFE THAN GAS MILEAGE"
    kudasai's Avatar
    kudasai is offline medium pimpin
    Oct 2004
    an jung ri, south korea
    1. gave up and took mine firestone. they said that the front alignment(done by the dealer a week or so before) had the toe set to almost double max. they aligned it and no more problems
    05 magnum rt
    83 300TD with waste veggie kit
    92 nighthawk 750.
    burn vegetable oil to work, burn rubber on the weekends!
    dansk is offline LX Padiwan
    I took mine in to an independant after the dealer told me that my alignment was not a warranty issue, I didn't have right pull, just terrible front tire wear. The shop corrected what they could and my car is on hte outer edges of being in spec but they said I would need to have my engine bolts loosened to fix it any more than what they could do.
