Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By TheBeej418
  • 1 Post By boggart
Thread: Turning Rotors.
    d794402000 is offline LX Newbie
    Jun 2010
    Turning Rotors.
    If your rotors are slightly warped will getting them turned help any? I have a slight shake/shimmy in the steering wheel at all speeds when I gently apply the brakes. When I lay on the brakes pretty hard it doesn't shimmy so I'm assuming a rotor is warped a little. Any thoughts? Thanks.
    TheBeej418's Avatar
    TheBeej418 is offline Got a little German in me
    Jan 2008
    Nashville, TN
    Sounds like turning your rotors should provide a temporary solution. I believe most places charge about $10/rotor. The reason I say it's a temporary solution is because most find that their rotors will warp fairly quickly again after turning. With the time/labor involved, it's darn near worth just replacing them.
    p.s. If you have slotted rotors, you probably won't find anyone to turn them.
    '06 Silver R/T with Road and Track on UAS
    silvermagR/T is offline Mopar Muscle
    Sep 2009
    Murphysboro IL
    I just bought replacements for 70 and some change per rotor so as stated above replacing them would be the best bet in my opinion.
    Mopar Or Bust
    6.1 Cam, 180 T-Stat, K&N Typhoon CAI, Predator with Custom Tune, Underdrive Pulley, Magnaflow Cat Back, BT Lock Out, Taylor Shorties and Much, Much More To Come.
    cbservices01's Avatar
    cbservices01 is offline ONE IS NOT ENOUGH
    Jun 2007
    houston tx-SCLX
    Can you see dark areas on the rotors? If you can, try steel wooling with some 0000. It might be residue coked on from a hard stop.
    boggart's Avatar
    boggart is offline LX Guru
    Pittsburg, KS
    Turning a rotor is no more a temporary solution than replacing the rotor. New rotors can/will eventually warp as well. Often times it is people driving habits that heat/cool the rotors so much that the warp more quickly than with other drivers. Habits either personal, or route taken requiring more braking...
    CT-MSRT likes this.
    desquirrel is offline LX Padiwan
    Jan 2005
    Rahway, NJ
    Other sources of judder: bad wheel bearing, control arm bushings, or tie rod ends.
    Montreal300's Avatar
    Montreal300 is offline Go Faster with Class
    Sep 2009
    St. Lazare Quebec
    Just replace them. Been there, done that and have the T shirt to prove it. Once they warp, they're scrap.
    Pedator, CAI, MDS indicator, ESP/BAS defeat switch, Tranzformer, blacked out wire mesh grille, smoked and flashing side markers, 9005 2400k 65W fogs, Euro rear fogs, debadged and demolded, 255/45/20 Nitto 420's, Boss 338 wheels, painted calipers. Glovebox & cup holder LED Mod. Blastin Bob 6db reso delete pipes. Euro LED side signal repeaters, 55/35 window tint, BT catch can. Color matched tail lights. Custom front lip. LED interior lighting.
    Next: Lower with BCR Coilovers.
    Hulkman44's Avatar
    Hulkman44 is offline LX Newbie
    Sep 2011
    Northern,VA
    I had the same exact front end shimmy a few months back. I had my uncle who is a pro mechanic, turn the front rotors and I went ahead and put new Stoptech pads on the front and the shimmy went away. Its been about 4 months and still warp free and shimmy free. Some places wont turn them so you may need to find someone on the side.
    "The greatest trick the devil ever pulled was convincing the world he did not exist. And like that... he is gone." VK
    Check me out on Car Domain: http://www.cardomain.com/ride/391268...-srt8-sedan-4d
    magmax06's Avatar
    magmax06 is offline Supercharged and Bagged
    Apr 2010
    Canada, Montreal
    I am hard on the rotor and have to turn them more than once !
    If they are far the wear limit on the tickness, you can turn them without problem
    I even keep the same pad and usualy good for another 20000 miles !
    I had now upgrade to R1 slotted rotor with stoptek pad and they didn't warp yet
    Better set up than SRT stock brake.
    Corkit's Avatar
    Corkit is offline LX Padiwan
    Apr 2012
    Langley BC Canada
    Quote Originally Posted by magmax06 View Post
    Hey Mag
    Where did you get them? My rotors are warped and I was trying to find a solution
    06 Magnum R/T
    ***** More to Come *****
    Jan 2005
    Rahway, NJ
    If you look, you'll see 3 rotors avail: "OEM", middle level (which is OEM sprayed with paint to limit rust and allegedly more closely balanced), and "performance" which is mid level with slots or drillings. Everybody sells the same exact rotors from China. Whether NAPA, AUTOZONE, Raybestos, they are all the same, and even have similar part numbers. Drilling and/or slotting do NOTHING but add bling and may cause serious issues. If you want a couple hundred rotors, a big guy like Brembo will stamp them "Bob's Brake House" or whatever and put any slot or hole design you want on them.
    In short, check around, and if you have a coupon or something that makes the mid level $.20 cheaper or whatever, get them there. Last time I got them, Autozone had web coupons that made them almost half price.
    Snuffy's Avatar
    Snuffy is offline formerly Mikey97D
    Feb 2011
    Prospect, CT
    When you either cut or replace your rotors please make sure you torque your wheels to specification. Otherwise your rotors will warp again.
