Delete/remove thread.
It is worthless without StarScan.
'05 Magnum RT: Borla 112, HHP High-flow cats, Frankentake III air intake, F.O.G projector headlights, painted calipers, SC FlashPaq, AR 311 20s w/ Nitto 420s. Practical car
'07 Porsche Cayman S: de-snorked, exhaust modifications, suspension, racing rubber. 4 years of autocrossing and DEs
Can't stop you from spending your money the way you want to :-) I bet FnkyChkn would agree with me though. BTW, where do you plan to get level to temperature ratio?
What about this. I'm about to have my trans leak fixed, therefore the level should be checked at the dealer. Then, get home and check the level cold (note the outside temp) the next day with said dipstick. Then, you should always know the proper level at that same cold temperature, right?
Is there a reason this would not work? Seems to me this would work with about any dipstick you could put in there. I heard one off a Ram truck was the correct size and length.
Hokie
Displaced Hokie
2005 Dodge Magnum R/T
Sounds like a good plan, let us know when it arrives..
Dodge Magnum RT AWD MDH=Jan 19th 2005 7-8pm
Tow package, Midnight Blue, Painted spoiler body colour, Auto headlights, HID lows, Fogs on with Hi beams, SC flash with custom tranny and 91 tune, RER MyGig installed, Tranzformer, Resonators deleted, Custom Stainless intake.
160,000km driven very hard, repairs include replaced front brake rotors and pads $200, rear pads$, ebrake shoes, all 4 tie rod ends $50ea (only 1 was loose), front sway bar rubber bushings $25(first thing to check if front is clunky); 3m refinished headlights WOW $30, 4 sets of tires, 2 tranny filter and flushes,
Anyone thought about using the engine dipstick?
MikeyB
2005 Brilliant Black Magnum RT
Why bother. If it has a leak, that will be obvious. It would have to be checked and fixed at a dealer anyway. If there is no leak, id gamble that its still full ....LOL
1966 Coronet Custom
(Homemade SuperBee)
