I plan on towing and am a firm beliver in a good cooler,what's avalable, who's got what, after market / police, fitting's ,(don't want to cut the factory line's) Also went to check trans fluid and there's a plug in the dip stick tub,whut's up wit dat ? also how do thease 545 rke tranny's hold up ? thanks
This would be a good option either way you are going to have to tap the tranny lines. Depending on how many lbs you are towing light loads should be ok
