I've been having an issue with my 05 SXT that has gotten on my nerves. I only have about 10,000 miles left on the warranty and I still can't find a dealership that can help me. Here's the problem:
Every so often, when I first start the car and drive a mile or two, the car will start hesitating. It starts surging and sputtering and the throttle response sucks. If I power through it, it'll eventually clear itself out, but it's still a problem. When I slow to a stop, the car jerks and sputters almost like a manual left in gear without pushing in the clutch. Then when I try to pull away from the stop, it'll spit and sputter again, till I power through it. The tach will bounch with the erratic RPM's, then when the problem has passed, the tach goes back to normal. I've tried finding a pattern (speeds, road conditions, weather conditions, time of day, etc) and the only thing I've found is it mostly happens after the car has sat a while (overnight, while at work, even in shopping). When all this is going on, the "engine" light flashes for a few seconds, then goes away.
I've taken it to a dealership and been told, "It's not doing it now so we can't tell you what's wrong. That'll be $65 for the labor of hooking it up to the diagnostic computer" After telling them where to look for that $65, i leave the dealership pissed off and nothing has been fixed. I life in NY and just had my car tested a week ago and of course, no trouble codes were found. I've gone to Auto Zone, no codes found. I've used a MacTools scanner, no codes. Every time it's started messing up, I've run to the dealership to get it looked at and it quits on the way there.
Anyone else run into this or have any ideas what it may be? I'd appreciate any help.
Bryan
