I did a couple of searches..but couldnt get a positive answer..06 Magnum..the rear Dodge Emblem..the Rams head..is that a stick on..or is screwed in.and have to take off the rear inside cover to get to the screw..May sound dumb..but some say it's screwed on
As far as I know, the only LX that has a rear badge that leaves a hole is the 300.
The Charger and Mag, the Rams head is glued on and comes off fairly easy.
Hair blowdrier works great--although tough to heat up on a cold winter day
Just use a flatblade to get it started on a corner and then gently pull with your fingers as you heat it up with dryer. Only the front emblem has some clips, no screws.
2005 Mineral Gray AWD Hemi Registry # 1154 Comp Cams 260 cam, Blastin' Bobs 9db, Dual Flowmasters, Gibson Shorty Headers, JBA High Flow Cats, Frankentake CAI, Techco Strut Barce, Taylor Shorties, 180 thermo, 85mm TB, Flastech Halos, Predator-tuned by Diablotoona. 2008 Magnum BB R/T Hemi Registry # 1584 PPP Stage 2 Cam, JBA Shorty Headers, JBA High Flow cats, Heartthrob Exhaust, Eagle Intake, 85mm BBK TB, LMI Intake, SMF Strut Brace, lowered, Tuned by Diablotoona
It's just stuck on, get it warm and use a piece of fishing line to get underneath it and work it back and forth until it cuts through the glue, then use an adhesive remover goo gone or something similar.
its just adhesive...mine is completely debadged in the rear and no holes. I once used nylon fishing line after heating so that I didnt damage paint but pulled the adhesive off with the badge![]()
Thanks guys..got my answer..now I can order the " Memory of 911 " from BT..I just didnt want to have to take off the inside back panel..I took the rest off the rear..hair dryer and fishing line..was easy..helps I live in florida..was just picking at the rear badge and it does look like it's just stuck on..thanks again
