You can buy aftermarket back up cam kits for around $100. I know of one that mounts on your licence frame and all you see is a pinhole, and has like a 2" monitor you can put on dash, visor, console or whatever. You can wire it to be on all the time or wire to backup lites to work only in reverse.
BTW, all cams like home security ones, are 12v powered. You just normally use an ac adapter for home use. Had a friend with a Ferrari Testa Rossa that removed the outside mirrors and put tiny bullet cams on the insides of both ' A ' pillars. Mounted 2 small monitors on drivers visor.
1966 Coronet Custom
(Homemade SuperBee)
