UPDATE 11/2/06
Got the Magnum back from the dealer this evening. I took it in for the TSB for tranny shudder and for the code that came up last week. I was not able to talk to any mechanic or service writter, but when I got the call that the Magnum was ready, I asked if they had to replace the torque converter and he said he did not. He did the flush -- 15 quarts of ATF on the receipt -- so I am assuming that was 3 flushes if I read the TSB correctly. I am also going to assume that they flashed the memory, since all my settings are back to default. I'll do a search to determine if the flash updated the software or not. The transmission seemed to shift better, but after I felt the shudder back several weeks ago in the rain, in the dry, I can't really say I felt that same shudder afterwards. It was so obvious that day, but less so afterwards. Finally, the trans tube was repaired. I guess this will take care of the issue. I can say again, that I was treated very well by the dealer. I just wish I could have talked to the mechanic who ran the StarScan for codes so I could have more details here for you.
Mike
Posted this again on Friday?
"This happen on Wednesday and posted here:
"Was driving into work today and at some point noticed that I had no throttle response -- it felt like the engine was off, but the RPM's were up to approximately 2000 in neutral. Got a ding and the engine light came on -- this may have been at the same time, but I'm not sure. It seemed that the engine quit, well not quit but quit responding to the throttle, and then the light came on. I got throttle resonse back and the light stayed on. This all happened in about 20 seconds. Of course, I'll go in for the light, but that odd feeling of the engine dying was quite a shock when you're in traffic and trying to figure out what the heck is going on. Has anyone had this? Does this have anything to do with the limp mode I've read about here? Any help is apreciated."
I did not get to check for codes that evening, but notiched yesterday at lunch that the engine light was off. I did the setup to check codes, but there were none stored.
Now I have no idea what happened. And now I can't recreate the problem for the dealer. If the code goes away, can I assume that the computer reset itself -- this does not sound correct, but I have no other theory.
Am I missing something? I have tried to read as much as I can by searching this problem here on the forum, but nothing even close is in the data base. Any insight is, as always, appreciated. Thanks in advance."
I did find a code P0700 today -- not sure why it showed today and not yesterday. Can anyone help me on what would cause this code and how is it related to the problem above?
Thanks again!
Mike
