Results 1 to 6 of 6
Thread: P0196 code
    Lost815's Avatar
    Lost815 is offline YEAH...I get all my Tattoos for free....
    Oct 2005
    In the driver's seat with the pedal to the metal!!! Salem, OR
    Arrow P0196 code
    anyone know the fix to this?
    bipto's Avatar
    New Hampshire
    According to the KB... DTC P0196 Engine Oil Temperature Sensor Performance
    The Iron Mistress Galleries
    R.I.P. Dave...
    Lost815's Avatar
    Oct 2005
    is this something to worry about?
    Meister's Avatar
    Meister is offline 300C pilot
    Arizona
    Quote Originally Posted by halo2
    Pulling fuse 11 in the forward PDC (fuse box - schematic on underside of lid) for 30 seconds or so will clear both the PO196 fault code and the resultant CEL (Check Engine Light).
    If you don't get a recurrance consider it a random electronic glitch. If it recurs I'd leave it uncleared and have a Dodge or Chrysler dealer check it out.
    I'd guess you have a 2006 model. Providing such information up front enables other members to better assist you.
    Lost815's Avatar
    Oct 2005
    sorry 05 magnum rt
    fnkychkn's Avatar
    greasy cardboard box
    P0196–ENGINE OIL TEMPERATURE SENSOR CIRCUIT PERFORMANCE
    • When Monitored: Engine off time is greater than 480 minutes. Ambient temperature is greater than 4°C (38° F).
    • Set Condition: The PCM detects the Engine Oil Temp value is incorrect by comparing it with the other engine inputs. Three good trips to turn off the MIL.
    Possible Causes
    (G224) ENGINE OIL TEMP SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
    (G224) ENGINE OIL TEMP SIGNAL CIRCUIT OPEN
    (K900) SENSOR GROUND CIRCUIT OPEN
    (G224) ENGINE OIL TEMP SIGNAL CIRCUIT SHORTED TO GROUND
    (G224) ENGINE OIL TEMP SIGNAL CIRCUIT SHORTED TO THE (K900) SENSOR GROUND
    PCM
